Anyone had problems with steering rack???
Old Feb 20, 2004 | 09:13 AM
CPETTY's Avatar
I have been having this rattle or clunking noise when going over bumps from both sides of the front of my car (99 SE) 84K mi. I had a Nissan mechanic put it on a lift and he thinks its the steering rack. The tie rod that connects to the rack fits like a ball and socket. You can feel play in the tie rod when you try to move it. When you tap on the wheel you can also hear a rattle noise it makes.
I guess its worn out. Anyone ever priced one or had any problems in this area??
cp
Old Feb 20, 2004 | 11:12 AM
ManualMaxima's Avatar
5th Gen till she dies!
i have but not that problem. mine was just leakning really badly. dealer replaced mine for free
Old Feb 20, 2004 | 11:40 AM
Broaner's Avatar
2060lbs and falling...
I have a knocking noise but I don't think it is from the rack. I am buying the bushings that connect the sway bar to the frame. Mine are shot and that is the suspect. If this doesn't work I will have Nissan check the rack. My method is: Do the cheapest possible fix first. Also, replacing your own rack would be a very complicated process.
Old Feb 20, 2004 | 12:00 PM
CPETTY's Avatar
Yea, I will not attempt to do that....
Old Feb 20, 2004 | 09:57 PM
Broaner's Avatar
Well, I installed the sway bar bushings and the knocking remains. I am so tired of dealing with this **** so I schedualed a diagnostic apointment with Nissan. If it is the rack I will have them replace it and if it is some other minor issue I will do it myself.
Old Feb 21, 2004 | 04:58 AM
Kevlo911's Avatar
Kevlo for President
It is prob you strut mounts, you hear when accelorationg at low speeds and over bumpy roads at low speeds, correct?
Old Feb 22, 2004 | 10:46 AM
CPETTY's Avatar
Hey, just replied to your thread with the pics. Didn't realize you replied to mine thread also. Anyway let me know what they tell you and how much the rack will be. I have'nt priced one yet. I know it's going to hurt.......
Old Feb 22, 2004 | 04:09 PM
Broaner's Avatar
kevlo911, which part exactly is the strut mount? Is it the 4" rubber seat at the top of the spring or the metal piece or what.
Old Feb 22, 2004 | 05:02 PM
CPETTY's Avatar
check this site out it explains it pretty good.... http://www.motorvate.ca/mvp.php/703
Old Feb 22, 2004 | 05:32 PM
SkinnyMax's Avatar
maxima no more
try replacing the tie-rod ends first, they are pretty cheap from advance auto, its a quick job, jacking up the car takes the most time
Old Feb 22, 2004 | 06:44 PM
Broaner's Avatar
Thanks CPETTY. Reading that makes me think its not the strut bearing. I used to have the binding spring issue but it went away. When it comes back I will replace them. Also, I have replaced endlink and bushings and FSB bushings. Not fixed yet.
Old Feb 23, 2004 | 01:38 PM
Kevlo911's Avatar
Kevlo for President
www.newnissanparts.com
Go there, choose your maxima. chose front sus, then -- I think-- components and then strut mount and click view. It will show you a pic of the front suspention and labeled parts.
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
mikeg75
Nov 30, 2015 05:12 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
