Greddy ignition Harness, Code 0201 Quick help please
Old Feb 20, 2004 | 07:19 PM
Redmax's Avatar
Redlinemax Owner
Da-max just rewired the ignition harness back into the car. The car runs great, however i get an 0201 code, what could it be? the car retards and advances timing perfectly and idles perfectly. I get the cose upon startup.
Old Feb 20, 2004 | 09:40 PM
BigDogJonx's Avatar
Whats odd is that you keep pulling these codes that are not even part of the FSM at all. 0201 doesnt show up in there.
But a general 0201 is Injector circuit malfunction cylinder1.
That still bugs me like I told you on the phone on how you are pulling all these codes that dont even show in the FSM.
Dixit
Old Feb 20, 2004 | 11:49 PM
Redmax's Avatar
Redlinemax Owner
but it does show on the ecu diagnosis sites, all of them check the fsm for the 2000 and see if they are in there. Remembeer the se-l is supposed to be slightly different from them all
Old Feb 21, 2004 | 07:26 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
codes, codes and more codes.....just wanna make sure I'm reading these codes right(Corey might be, but I'm not sure myself)...the first slow flashes are the first number and the second set of fast flashes is the second number?? thats how it was on my 3rd gen, if I can remember
also I wonder if that code ONLY appeared after we messed with the timing?
Old Feb 21, 2004 | 08:09 AM
Redmax's Avatar
Redlinemax Owner
it did only appear after the timing I was pulling codes all week. After last night we can attest that this car is running perfectly fine!!!!!!!Man you should have caught our top end runs on 50 After 110 my car REALLY SHINES!!!!I need thaut exhaust on bad though! every time i let my foot off the gas it like i'm hitting brakes.
Old Feb 21, 2004 | 08:22 AM
BigDogJonx's Avatar
Corey, you gotta get that $30 obdII reader so we can make sure we pulling the codes accurately. Or roll to an autozone in the mean time while you order that reader.
Even the early 2000 FSM shows codes 180 and 217. Nothing in between.
Dixit
Old Feb 22, 2004 | 08:19 PM
DA-MAX's Avatar
Corey...this is gonna be a pain, but if you want lug your desktop comp into the garage and take the timing out that I set and see if the code still pops up....probably won't but you just might wanna check.
also does anyone have info on how timing adv/retard on coilpack systems work?? I'm a little confused on that...I assume the ECU just sends a corresponding voltage signal that tells the coils to retard or advance? also would the OEM knock sensor interfere in anyway??
right now I advanced him 1* degree throughout in vaccum and -1* in boost just to see what happen and it runs nice and clean...I'd be more comfortable with boost referenced retard(ie- X* per pound of boost), but ah well...we'll see this saturday hopefully
Dixit...does the OBDII reader show real-time timing??
Old Feb 22, 2004 | 08:33 PM
BigDogJonx's Avatar
My OBDII does show the timing advance.
Mar 12, 2020 12:06 AM
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
Sep 5, 2015 10:10 PM
