where are you shifting to get optimum gas mileage?
Old Feb 21, 2004 | 08:26 AM
kingrukus's Avatar
no more maxima...
As the subject states, where are you shifting to get optimum gas mileage? For my daily commute, I try to shift below 2300 rpms for every gear. My car still is not giving me great range on a full tank. I know there are many other factors that come into play with gas mileage, but I am only focused right now on the shifting.
Old Feb 21, 2004 | 08:46 AM
AsthmaMax11's Avatar
right at 2500
And I still get crappy mileage.....
Old Feb 21, 2004 | 08:56 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
dump the 18's and stereo equipment.
Old Feb 21, 2004 | 08:59 AM
Phatmax98's Avatar
I shift right around 3-3.5k, my car doesn't like being shifted at low rpms...I get about 300-350 per tank at this rate
Old Feb 21, 2004 | 09:57 AM
kingrukus's Avatar
no more maxima...
Well the 18's haven't even gone on the car yet...and they are not exactly boat achors either (18.6 lbs a piece).
Old Feb 21, 2004 | 10:49 AM
Maxjm's Avatar
Around 3-3.5k as well. That is where I learned to shift, even in my old 86 Subaru station wagon.
Old Feb 21, 2004 | 02:47 PM
s3roush628's Avatar
How much of that is highway driving? I get about 225 mpg on my auto with mostly city.
Old Feb 21, 2004 | 03:05 PM
Max Noob's Avatar
shift at like 3- 3.5 this is the optiumum rpm range for cruising for the maxima.. below that you are probably running a little rich on acceleration.. above that the rpms is too fast to get good milage.
i average 22-24 mpg.
Old Feb 21, 2004 | 03:19 PM
geo1317's Avatar
look in your owners manual, it tells you when to shift in there.
Old Feb 21, 2004 | 03:23 PM
nismos14's Avatar
§è~® f®ÈÄk
it does? too bad i dont have mine... so what does it say?
Old Feb 21, 2004 | 03:31 PM
geo1317's Avatar
i wish i knew where mine was too, i just remember seeing it in there.
Old Feb 21, 2004 | 03:37 PM
nismos14's Avatar
§è~® f®ÈÄk
well someone look in there
Old Feb 21, 2004 | 03:38 PM
sadice's Avatar
Old Feb 21, 2004 | 08:05 PM
Phatmax98's Avatar
Not a whole lot of highway around here...so I don't know how your mileage is low. Do you drive aggressively? I do, but it's not that often.
Old Feb 21, 2004 | 09:50 PM
kingrukus's Avatar
no more maxima...
Do you mean 225 miles per tank? If so, that is LOW.
Old Feb 21, 2004 | 09:58 PM
Bmr4life's Avatar
what about us automatic guys?
Old Feb 21, 2004 | 10:33 PM
kingrukus's Avatar
no more maxima...
Old Feb 21, 2004 | 10:38 PM
geo1317's Avatar
good to see someone still has their owners manual
Old Feb 22, 2004 | 02:23 PM
PLUMMAXSE's Avatar
Originally Posted by kingrukus
Hell I did 100 in 3rd in mine? Guess the book doesn't mean that.
Old Feb 22, 2004 | 02:35 PM
nismos14's Avatar
§è~® f®ÈÄk
r u sure? i can't do 100 in 3rd in my 5 speed
Old Feb 22, 2004 | 03:46 PM
WillMax95's Avatar
i dont have a stick on my maxima, but my other car (not mine, my parents) ive driven a while back (a GT) and i shifted at 3000 RPMs and got pretty good milage
Old Feb 22, 2004 | 03:55 PM
wariow's Avatar
I always try to shift before 3k rpm. I get pretty bad gas mileage. I get like 250-300 on 16 inchers.
Maybe I'll try shifting around 3500 rpm.
Old Feb 22, 2004 | 04:36 PM
ManualMaxima's Avatar
5th Gen till she dies!
i shift at 3.5 as well, i would rather waste gas then have to think about granny shifting every time i do it....that is too much thinking
Old Feb 22, 2004 | 04:42 PM
s3roush628's Avatar
bad mileage
Thats right kingrukus, only 225 miles per tank:-(. Its all city driving in my automatic thoughL I dont top off though and try not to run it to low fuel light. Is there something wrong with my maxi?
Old Feb 23, 2004 | 12:21 AM
sryth's Avatar
It says suggested maximum speed.
I've gone past 100mph in 3rd as well.
[edit]Oh, yeah...I keep it between 2k and 3k when I'm being nice [/edit]
Old Feb 23, 2004 | 12:40 AM
happyricefob's Avatar
V^___^V
never pass 3,000rpm all gears. 320mi/tank with 50% local 50% hwy driving w/ ghost 0304 CEL . mobile 1 sythentic 5W/30 + OEM nissan filter + 91 octane.
Old Feb 23, 2004 | 08:01 AM
Dave B's Avatar
Not DAVEB the parts guy
For those you that can go over 100mph in 3rd, either you're an automatic or your speedometer is off. It's impossible to any faster than ~96mph in 3rd with the stock rev limiter With my 7000rpm limiter, I can only do ~102mph in 3rd.
As for shift points and MPG, I shift my 1-2 at approximately 4000rpms, the 2-3 at ~3800rpms, and the 3-4 at approximately 3000rpms. A lot of the time I go directly from 2nd to 4th. I tend to play around in 2nd and 3rd quite a lot revving it to 5000-6000rpms a few times a day. I usually get 22mpg with 80% city and 20% highway. I usually get 26-27mpg in straight highway driving.
Dave
Old Feb 23, 2004 | 05:36 PM
sryth's Avatar
What makes you say that?
Old Feb 23, 2004 | 05:50 PM
Shift_my vq's Avatar
I get between 300-350 on a tank of 91. And the way I do it is I skip gears. I start out in first or second, and shift to 4th or 5th gear. And don't floor it just give it a second and it gets there. And I just took the car for a spin and I did 100 in 3rd gear????
Old Feb 23, 2004 | 06:37 PM
sryth's Avatar
I think our tires are over-inflated
Old Feb 23, 2004 | 08:03 PM
MaxiSpeed97's Avatar
i used to get almost 400 for the tank with CAI and using mobil 1 synthetic shifting at 2800 or so, but now, after going to non-synthetic and gettin full exhaust and gettin a weird CEL 0305 i think, i barely get to 290, but the weather changed so i dont know what exactly caused it
Old Feb 23, 2004 | 08:30 PM
kingrukus's Avatar
no more maxima...
I pride my self on gas mileage. Within the next few months I will be changing plugs/fuel filter, ripping out stock intake system with dirty air filter and replacing with clean franken car system, replacing stock b/y with aftermarket b/y and cleaning cat. Hopefully with that, and under regular driving, my range per tank will sky rocket. Right now I can get about 340miles (~550km) per fillup if I am lucky and take it right to the low-gas warning light.
Old Feb 23, 2004 | 08:52 PM
Phatmax98's Avatar
Holy crap! I drove 265 miles recently..mostly highway and only used half a tank! I noticed this tonight when I went to the store tonight. Oh and BTW I have 2 codes for my SES light. So...265 x 2 = the other half of my tank is what..about 530 total? All I can say is wow.
Old Feb 24, 2004 | 12:15 AM
sryth's Avatar
That's a very inaccurate way to measure mileage. Here's the best way:
Fill up; reset trip meter; drive a lot; Fill up
Take the mileage on the trip meter and divide by the number of gallons on the 2nd fillup.
If you're really hung up on accuracy, use the same pump for both fillups.
Old Feb 24, 2004 | 07:16 AM
Dave B's Avatar
It's a pretty easy calculation. Every 1000rpms in 3rd gear equals 14.9mph. 14.9mph times 6.5 (the stock 6500rpm rev limiter) equals a maximum speed of 96.85mph in 3rd gear. It's impossible to go any faster in 3rd without a raised rev limiter.
At 6500rpms:
1st 37mph
2nd 66mph
3rd 97mph
4th 129mph
5th 153mph
http://www.boostaholic.com/maxima/dyno/shiftpoints.html
Dave
nismos14's Avatar
§è~® f®ÈÄk
plus the second half of the tank never yields the same as the first half, the fuel gauge is inaccurate
Old Feb 24, 2004 | 07:18 AM
Dave B's Avatar
I wouldn't put much faith in measuring that way. The gauge is slow to react. I'm currently at 120 miles and have only used a 1/4 tank. I know for a fact that my car will not be getting 480+ miles on a tank.
Dave
Old Feb 24, 2004 | 07:43 AM
Phatmax98's Avatar
Dave
Yeah..the best I have actually got was around 400 on a fillup...but it's nice to dream
Old Feb 24, 2004 | 04:42 PM
sryth's Avatar
At 6500rpms:
1st 37mph
2nd 66mph
3rd 97mph
4th 129mph
5th 153mph
Dave
Pretty good link!
As for the speed, I get different numbers. Again, it all depends on tire inflation.
Code:
F	3.823	Input	Axle			Tire:	215	55	16
1	3.285	0.304	0.080			Height:	25.31
2	1.85	0.541	0.141			Circumference:	79.52
3	1.272	0.786	0.206
4	0.954	1.048	0.274
5	0.795	1.258	0.329
R	3.482	0.287	0.075
	Axle Revolutions
	1000	1500	2000	2500	3000	3500	4000	4500	5000	5500	6000	6500	6550
1	80	119	159	199	239	279	319	358	398	438	478	518	522
2	141	212	283	353	424	495	566	636	707	778	848	919	926
3	206	308	411	514	617	720	823	925	1028	1131	1234	1337	1347
4	274	411	548	685	823	960	1097	1234	1371	1508	1645	1782	1796
5	329	494	658	823	987	1152	1316	1481	1645	1810	1974	2139	2155
R	75	113	150	188	225	263	300	338	376	413	451	488	492
	Wheel Speed
1	6.00	8.99	11.99	14.99	17.99	20.99	23.98	26.98	29.98	32.98	35.98	38.97	39.27
2	10.65	15.97	21.29	26.62	31.94	37.26	42.59	47.91	53.23	58.56	63.88	69.20	69.74
3	15.48	23.23	30.97	38.71	46.45	54.20	61.94	69.68	77.42	85.17	92.91	100.65	101.43
4	20.65	30.97	41.29	51.62	61.94	72.26	82.59	92.91	103.23	113.55	123.88	134.20	135.23
5	24.78	37.16	49.55	61.94	74.33	86.71	99.10	111.49	123.88	136.27	148.65	161.04	162.28
R	5.66	8.49	11.31	14.14	16.97	19.80	22.63	25.46	28.28	31.11	33.94	36.77	37.05
[edit]If anyone wants the Excel file for this, PM me.[/edit]
Old Feb 24, 2004 | 10:34 PM
Bmr4life's Avatar
why does it depends on tire inflation? Are you guys refering to the actual speed the car is going or just what the speedo says? If your saying actual speed, then yeah I see where tire inflation/size comes into play but that would still be an inaccurate equation unless you measured the tires circumfrence when its spinning because I think the tires would balloon a little depending on the rpm.
