metal grinding when i make right turns
Old Feb 22, 2004 | 09:48 AM
95maxcntrljrsy's Avatar
it sounds like brakes rubbing - any ideas
Old Feb 22, 2004 | 10:26 AM
bump bump bump bump
Old Feb 22, 2004 | 02:32 PM
RyCrisp's Avatar
Mine is starting to make that noise too. My friends are telling me it's my wheel bearing because it makes a slight jingle noise when I turn right also. My right axel boot is separated from the joint so I'm replacing that as well. But not sure if you have the same problem. Mine has got consistently worse over the past couple months...just got money now to totally replace everything on my car and do performance upgrades so I've kinda neglected it lately.
Old Feb 22, 2004 | 03:26 PM
Shingles's Avatar
The missing moderator
could be a couple of things. Check your brake pads to make sure they aren't worn. The other is to check the dust shield behind the rotors. Make sure it isn't touching.
Old Feb 22, 2004 | 03:42 PM
SkinnyMax's Avatar
maxima no more
if your CV boot is ripped then it may be your cv joint that has crap in it and is now worn out and needs to be replaced
Old Feb 23, 2004 | 03:51 PM
Tjd135's Avatar
I hv the same proble.. I dunno what it is
alixc
Aug 11, 2020 01:48 PM
sake1bs
Sep 19, 2015 09:32 PM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
