Cold Start Problem Acknowleged by Nissan - TSB Issued
Old Feb 24, 2004 | 10:59 AM
cmbott's Avatar
Just received a call from my dealer today regarding the cold start problem I have been having (problem very similar to others)
- one morning car stalled while being warmed up (around 15 deg outside) after restarting, it would only go about 20mph and not above 3000 rpm
- two other times, it flat out would not start at 18 degrees or below
- has a difficult time starting when below 35 degrees (eventually it "catches" and then runs roughly for a couple moments at 750 rpm's before kicking into 1500 rpm fast idle
So, Nissan finally put out a TSB (today, I believe) and they indicate that in the "Northeast in extreme temperatures of 15 degrees or below, the Fuel Pump fails" (paraphrased per my phone conversation with the dealer). Nissan will replace affected fuel pumps (Mine was ordered first thing today...nice to have a dealer who is also a neighbor to put the pressure on Nissan to deal with the problem)
Old Feb 24, 2004 | 11:02 AM
CanadianMoFo's Avatar
Great! I've been stranded twice by this problem.
What is the TSB# and is there a link to it so I can print it out for my next trip to the dealer?
CM
Old Feb 24, 2004 | 11:17 AM
cmbott's Avatar
CM
I'll see if I can get it....just called the sales manager, with whom I deal, and he doesn't have the actual info....my car should be going in on Tuesday (will try to get it then)
Old Feb 24, 2004 | 12:59 PM
Once we have the info it should be added to the TSB sticky at the top of this forum.
trasmadean
Jan 20, 2018 05:05 AM
02PearlSE
Oct 7, 2015 02:12 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
