204whp, 198tq - 1996 SE manual
Mods:
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
UR underdrive pulley
Stock clutch/flywheel
graph shows my previous dyno as an automatic (with faulty rpm switch on the MEVI), and then after the 5spd swap.
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
Originally Posted by 96sleeper
Mods:
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
Originally Posted by j_bryan
I'm also curious why you went w/ 2.5 exhaust piping rather than 2.25. I thought that 2.25 was good enough for NA.
Most aftermarket exhausts are 2.5"... generally only the cheaper ones are 2.25".
Originally Posted by audiyoudo
nice numbers! is that a wheel dyno or chassis dyno (ie. did you have to take your wheels off to dyno your car or just "drive-on"?)
Originally Posted by michaelnyden
what rpm is your rpm switch on your mevi set at?
I have the summit switch so it is set at a weird rpm, I don't remember what it is. I just adjusted it on the dyno until there was no dip in power. The engagement point seems to be 5300 rpm.
Mods:
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
Do you know what the temperature and humidity were at the time? The dyno graph should show it if you have it on disk. What is the Correction Factor?
Have you done any 1/4 mile passes with this setup or before?
Originally Posted by speedemn
Excellent numbers!!! This has got to be the highest NA MEVI'd numbers out of a gen 4 Maxima!
I don't know the temp but it was a little warm that day. I believe the correction factor was 1.01, so not very much. I went to the track alot as an automatic tranny, but not yet with the 5spd.
is the 70 mm tb is from a pathfinder? What year pathfinder did you use that fits a 4th gen?
none of them fit a 4th gen. The TB is from a 2001 pathfinder, you have to make an adapter plate to make it work.
Dave
Originally Posted by Dave B
Yep, he has the highest numbers. Requin6 (Paul) dynoed his 96 SE with the MEVI/JWT ECU/intake/y-pipe/UDP and pulled 200fwhp/198fwtq. Not bad I must say.
Dave
Dave
Edit... oh wait, I got b-pipe and flywheel too.
Sweet numbers nonetheless
Originally Posted by Jeff92se
Great numbers! Your pulling bigger numbers at the wheel than the rated flywheel numbers!
TB. What did you have to do for the TPS and the other various vacuum connections?
TPS is the same, I just calibrated it to the maxima values per the haynes manual. I removed the fast idle cam/cold start from the TB and just bypassed the vacuum connection on the bottom.
Nope. Iron Lung made over 210WHP with the STOCK redline.
The extended redline has nothing to do with more power, the peak power occurs before the stock redline anyway. It just provides more area under the curve. It is not just peak numbers that show how fast a car is, it is the area under the curve. I posted a comparison between me and iron lung's dynos that is pretty interesting. The torque of the ecu sure is nice, I wish there was one for the 99's so he could see what numbers he pulls. I am trying to decide whether or not I want cams or FI.
Just stated that his HP #'s are the highest (in response to the post i quoted) and will get even higher once an ECU becomes an option for him.
Much props to you though...
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
