CV Knock
Old Feb 24, 2004 | 08:30 PM
Hunter11's Avatar
CV Knock
I got the knocking sound like my CV boots are busted but they aren't. Is the grease that lubs them dryed up or something? Will I have to replace the whole joint?
Old Feb 24, 2004 | 08:43 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
It sounds like you took it a part to see if the grease is dryed up. I mean how do you know if the grease is dryed up, with out the CV boots being busted open.
well if you think they are dryed up and you continue to drive your car like this you going to changed them no matter what, because they will over heat and break the cv joints.
Old Feb 25, 2004 | 06:19 AM
Hunter11's Avatar
Originally Posted by CystumMax
It sounds like you took it a part to see if the grease is dryed up. I mean how do you know if the grease is dryed up, with out the CV boots being busted open. .
How does it sound like that? I was asking questions, not saying that is exactly what happened. If I knew what was going on why would I have made this post?
No I haven't taken them apart I was just guessing because isn't that what makes them usually knock when the boot tears and the grease gets slung all over the place? Right?
What else makes the knocking noise beside no grease in the joint? Just wondering,not trying to sound like I know what is going on.
Old Feb 25, 2004 | 06:47 AM
BC_95GLE's Avatar
If your hearing a clunking noise and it's from the drivers side than that one is no big deal to replace you just need a socket large enough to loosen the axle nut if its your passenger side one than that one is a little more tricky not something for the beginner to attempt.
Old Feb 25, 2004 | 06:58 AM
shnoog's Avatar
I agree that the passenger side is not something for an ameature to attempt. I replaced the passenger side on a 96 GXE and I have been a mechanic for a few years and still had some problems. But if you are going to replace it I found the easiest way is to take off the 3 bolts that attach to the engine block and rotate the mount to remove the axle. Trust me it takes patience but it can be done in a driveway.
Old Feb 25, 2004 | 07:56 AM
SkinnyMax's Avatar
maxima no more
yeah that bracket holding the bearing on the passenger side was a pain, the easiest way to get it off was to remove the bracket with the axle and then beat the bracket off the axle while it was removed from the car
Old Feb 25, 2004 | 09:32 AM
97GLE's Avatar
Strange... I've never had trouble getting the axles on and off the car... the hard part is seperating the CV joint!! Or are yall using split boots?
Old Feb 25, 2004 | 10:32 AM
SkinnyMax's Avatar
maxima no more
whatever you do, don't use the split boots. it is impossible to keep them clean while putting them on and the seam will split in 3 months and then you will end up putting a real boot on anyway
Old Feb 25, 2004 | 02:42 PM
97GLE's Avatar
I wouldn't put a split boot near my car, the real ones break fast enough (85,000 mi for me). So do you know an easy way to seperate the CV joint?
DC_Juggernaut
Sep 28, 2015 04:07 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
