What can I expect for a 1/4 time?
Assuming of course that I get a good launch and dont spin.
I will be running about 2850 lbs (no passenger or rear seats and everything else easily removed out of the car)
5lb flywheel
12 lb rims
Bridgestone S-03s 225/50/15 -unfortunately 25 lb tires- good traction for streeties tho
about 18-20 PSI in front tires
MEVI
JWT ECU
96 Octane petrol
Full exhaust (Stillen Y/B/Muffler)
Underdrive Pulley
Hi flow cat
Short thow shifter...
Thats about it... I know most of it is going to be driver ability but I want to know if I drive it right/really well - What can I hope to hit? Just curious to hear what people think... I have an idea of what I would be happy with but want to compare it to the gallery's...
*EDIT* it will be at about sea level around 50 degrees...
Cheers!
5lb flywheel
12 lb rims
MEVI
JWT ECU
96 Octane petrol
Underdrive Pulley
Hi flow cat
Cheers!
Anywhere from 14.1 to 14.6 depending on your driving skill and the track's available traction. If you can pull a 2.1X 60', you should be looking at lower 14s. If you get 2.1-2.3 60 foots, you should be looking at ~98-99mph traps.
That 5lb flywheel may hinder you though because it will make launching an absolute *****. With 75% less rotational inertia, the VQ will bog off the line if you can't keep the rpms high with a ton of clutch modulation. Light flywheels are good for road racing, but not for drag racing.
Dave
Dave
Dave
Dave
trungg86
Sep 4, 2015 04:58 AM
good one
