View Poll Results: Hey spring owners, how far did you cut your bumpstops? See pics for reference
1 in front & 1 in back
25
17.86%
1 in front & 2 in back
3.57%
1 in front & 3 in back
0%
2 in front & 1 in back
4.29%
2 in front & 3 in back
1.43%
3 in front & 3 in back
0.71%
Beyond 3 in front or back
0.71%
Only trimmed the back
3.57%
Didn't trim the bumpstops
95
67.86%
Voters: 140. You may not vote on this poll
Hey spring owners, how far did you cut your bumpstops?? *Pics for comparision*
Old Mar 4, 2004 | 08:52 PM
housecor's Avatar
Okay, take a look at the pics of the front and rear bump stops below and vote the amount that you trimmed your bumpstops! Please also mention what springs you're running and the amount you trimmed after voting. Thanks guys.
Front:
Back:
Old Mar 5, 2004 | 07:47 PM
housecor's Avatar
Bump.
123456
Old Mar 6, 2004 | 02:23 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Maxspeeds, stock struts, no trimming.
Old Mar 6, 2004 | 03:15 AM
MrGone's Avatar
Eibach/Tokico no trimming.
I did however use the ones that came with the Dust Boot replacement kit.
Old Mar 6, 2004 | 04:24 AM
NT2SHBBY
Maxspeeds/GR-2's no trimming
I think the only springs needing trimming are the teins-which as we have found out aren't really "performance-oriented" springs
Old Mar 6, 2004 | 04:35 AM
2k3TitaniumSe's Avatar
Why do Maxspeeds look so low on your max sig?
Old Mar 6, 2004 | 05:04 AM
NT2SHBBY
thats me pretendin I got JIC's and 19" versions of my already pimp 17's
Old Mar 6, 2004 | 11:22 AM
maximamaybe's Avatar
Same with my maxspeeds.
Old Mar 6, 2004 | 03:14 PM
jerome johnson's Avatar
Front:
Back:
Eibach with Tokiko HP trimmed bumpstop #2,3front and just #3 on rear
Old Mar 6, 2004 | 03:49 PM
MaxSE03's Avatar
Tein S. Tech = 1.0" front and 1.3" rear.
Old Mar 15, 2004 | 08:30 PM
redstradic's Avatar
I installed my H-tech and GR2s this past weekend. Teins recommended to cut the bump stops in the front and rear. What I did was take the bumpstop out of the dustboot. It was that little hard pale piece at the top of the dustboot. I cut an inch off the bottom of the bumpstop. There is no need to cut the dustboot and bumpstop together. That way the dustboot will still fit nicely up into the top hat.
However, i did not trim the rear because when i fully compressed the strut and springs, it did not hit the bumpstop at all.
Old Mar 16, 2004 | 06:42 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Sorry, but I'm slightly confused by your post. What do you mean they aren't "performance oriented"...in what way?
Old Aug 26, 2004 | 06:37 PM
irish44j's Avatar
retired moderator
That is what I am doing too.....take the oragne/pink part out of the boot and cut IT, not the boot. Looking at housecor's pics, though, it appears that the 2k2-3 dust boot is slightly different from the 2k-2k1 boots.....
Old Aug 26, 2004 | 07:55 PM
ZIPPIN's Avatar
Mauja He Mauja
what they said
Old Aug 26, 2004 | 08:10 PM
irish44j's Avatar
retired moderator
Originally Posted by dba1999us
what they said
dba - have you ever bottomed out the bumpstops, especially if you had weight in the trunk and people inthe back seats?
Old Aug 27, 2004 | 04:02 AM
vqman
housecor is the poll master...
ahaha
-vq
Old Aug 27, 2004 | 08:57 AM
00MaxSE's Avatar
Pointy Elbows
Hey housecor, I got my Progress springs and Illuminas yesterday. Do you recommend going with what you did on the bumpstops?
Old Aug 27, 2004 | 09:23 AM
BP2K2Max's Avatar
i cut the front at about halfway before the first increment ( i guess it's be about .5) and i didn't cut the backs at all. i have a very modest drop though(H&R's) so i probably didn't even have to cut them at all. It rides just fine
Old Aug 27, 2004 | 09:54 AM
MaximaPolak's Avatar
I have S-Techs, no trimming, because i have no new shocks.
When I buy Illuminas and install them, I'll cut the stops to 1
Old Nov 1, 2004 | 06:14 PM
irish44j's Avatar
retired moderator
I cut the pink inner bumpstops, not the boots themselves....
Old Nov 1, 2004 | 06:27 PM
njmaxseltd's Avatar
I take 2 off front and rear on every sport/lowering spring setup I install.
Old Nov 1, 2004 | 06:42 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I bough tokico blue and actually it does not go by inches. its actually millemeters it looks about #1 for the front and in between 1,2 for the rear.
sorry but my mech did it with a micrometer. hope it helps................
Old Nov 26, 2004 | 09:02 PM
ZeRo MaX's Avatar
Do you have to cut the bumpstops when you install new struts and new springs?
I wanna get Illuminas and Tein S-Tech Springs
Old Nov 27, 2004 | 06:20 AM
panda_1's Avatar
yeap same here.
Old Nov 27, 2004 | 06:44 AM
ghostrider17's Avatar
Who wants some trim?!
Housecor --
No offense, but I THINK this poll is stinted:
Since not EVERYONE that views this poll may be lowered or modified, they overwhleming answer of "DID NOT TRIM BUMPSTOPS" is problably not accurate.
This could be misleading.
The responses of course, do reflect the vast majority of dropped rides were, or Should be TRIMMED.
Just my 2 cents
For the record: I'm not sure if mine are trimmed, but I know they SHOULD be!
gr
Old Nov 27, 2004 | 08:03 AM
ddpack's Avatar
Cut # 1 in half for rears and eliminated # 2 in fronts. Worked great!
Old Nov 27, 2004 | 10:15 AM
maximadave's Avatar
detailerdaveb@gmail.com
I had a friend of mine at the dealership do mine when he installed my Illuminas. He told me he cut all four in half. The only problem I have is when the suspension compresses when I hit a pothole or a road that is misaligned while going over a bridge. Kind of a nasty noise and the dash rattles when it happens. People tell me its just the bump stops and not to worry.
Old Dec 4, 2004 | 07:52 AM
Get some trim
I finally got back to my installer to MAKE him trim my bumstops, since he didn't the on the original install as per my explciti instructions.
I'm on Progress and Illuminas, and the car was bottoming-out on EVERYTHING!!!!!
Mark me down for #1 fr / #2 rr.
What a HUGE difference! I think I would have gone 2/2 in retrospect, but still....trim your bumstops if you're lowering guys!
gr
***Special thanks to NJMAXSELTD for helping me out on the phone yesterday!!!*** You KNOW YOUR ****, Tom!
Old Dec 4, 2004 | 10:19 AM
ZIPPIN's Avatar
Mauja He Mauja
only once. when it hit a huge pot hole and the whole wheel fit right in the pot hole...
Old Dec 7, 2004 | 09:05 PM
Galo's Avatar
Maxima Pilot
When I installed my first springs -the Eibachs- I trimmed the stops per Eibach's recommendations 20mm front and 30mm rear -which made sense given the Maxes poor (short) suspension travel.
Wrong move as it iot made for very harsh, loud 'bangs' when the strut compressed all the way.
When I installed the H&Rs, I bought new, stock bump stops, installed them and the car is now perfect...the front struts do compress against the bump stops on big bumps but now it's a smooth take-up, not a harsh bang
Live and learn.......
Old Dec 7, 2004 | 09:17 PM
Puppetmaster's Avatar
I have Progress springs on and have not cut the bumpstops, despite what people are telling me.... I feel the same way you do... it rides fine even though I do have to be a little more careful with the front over certain bumps....
Old Dec 7, 2004 | 09:46 PM
BlkShadow01
get sum 12 inch subs n bumP!!!
Old Dec 8, 2004 | 05:37 AM
Audtatious's Avatar
Bandwagon Lover
Eibach with Illuminas, no need to cut bumpstops as the suspension is not allowed to travel that far
Eibach with stock, car was smacking the rear bump stops over every big dip on the highway
Old Dec 15, 2004 | 05:31 PM
Malecki2k3's Avatar
progress with illuminas,I didn't cut anything and feels good
Old Dec 16, 2004 | 07:07 AM
The Voice of Reason
This is not inflamatory - and I don't want to start a war between myself and the guys who didn't trim.....but,
Please get back to me after about 10k miles, and THEN tell me how it feels.
I'm telling you guys -- trim them while you can, it gets unbearable!
gr
Old Dec 17, 2004 | 08:19 AM
2K3MAX2NV's Avatar
"tse-tse fly"
i have tokico blues coming and gunna buy progress springs where do the bumpstops come into play????
Old Dec 17, 2004 | 08:25 AM
Dude....you REALLY need to read b-4 asking that question, ESPECIALLY since the answer lies within this VERy thread.
Start at page one. This is really THE best thread for that answer.
gr
Old Dec 17, 2004 | 09:36 AM
2K3MAX2NV's Avatar
"tse-tse fly"
gr
Dude..the pics dont work and i READ THE THREAD and maybe i dont understand what a dust boot is and what it means when u say they need to be "cut" or not SO RELAX not everyone on here is as smart as you
Old Dec 17, 2004 | 03:55 PM
aussie983's Avatar
Its pretty straightforward. When you go over larger bumps and rough road, the spring compress a lot depending on your setup. The dust boot covers the strut to protect it from dust...duh. So when you "bottom out", you end up hitting the boot, so you cut off part of it to compensate for that extra travel.
Old Jun 20, 2005 | 04:04 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Maxspeed and Illuminas and no trimming......at all
