problems with turbo kit
Old Mar 5, 2004 | 08:34 AM
tonio's Avatar
i hope someone can help me with my problem. Had the kit installed, its set at five pounds of boost. whenever i get to five pounds of boost snd stay there i get white smoke out of the tail pipe. when i drive in vacuum (excuse spelling) there is no smoke. can someone please tell me what i'm doing wrong my car is a 99 sel. does this car come with a stock fuel cut? I really need help. the kit was installed by a local pro shop. they put the probe for the egt on the down pipe is this the right place to put it? oh by the way, i'm posting under my friends name. my new sn is leGendre for some reason i cant post. the car is in the shop right now someone hit it. i have the e-mange, mevi,550 injectors and aquamist to go in. but i wont put any thing in till my first problem is fixed i can use all the help i can get. here is my # 646- 772-2504 call and i will call back, to save phone charges.
Old Mar 5, 2004 | 09:24 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Why not take it back to the shop?
What does the smoke smell like?
Is there any substance in your muffler tip?
Is your radiator fluid in your over flow tank going down?
Is your oil low?
It could be water, oil, gas, etc...
Old Mar 5, 2004 | 09:28 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
White smoke is oil, right?
I'd say your turbo seals are bad and when under boost, they allow oil into the turbine section, which makes white smoke out the exhaust.
Was the turbo new/used? Did you use a turbo timer?
Just a *GUESS* though.
Old Mar 5, 2004 | 10:09 AM
Morfeus17's Avatar
Yeah sounds like your seals on the turbine... You may want to try adding a thinker grade oil, like 5w-50 or maybe a bit of lucus oil stabilizer.... By the way, what are the specs for your turbo???
Old Mar 8, 2004 | 10:01 PM
Redmax's Avatar
Redlinemax Owner
also check the clocking of your turbo. The oil return line should be no more than at a 30 degree angle, if it is thent the oil will leak through the seals. it takes 20 minutes to reclock the turbo and get the smoke gone
Old Mar 9, 2004 | 08:20 AM
MardiGrasMax's Avatar
Did the shop prime the turbo with oil before start up?
Old Mar 9, 2004 | 02:47 PM
Bags's Avatar
I am curious to how to "prime" it???
Old Mar 9, 2004 | 02:58 PM
IceY2K1's Avatar
We just put a hose on the inlet and then kept filling it with oil and spinning it.
Then we got aggressive and put some compressed air on it to force it in.
Just don't use very much pressure, because you could damage the seals, however oil pressure is what 40-50psi? So, as long as you don't get carried away I think it's fine.
Old Mar 9, 2004 | 05:04 PM
I filled the pressure hose with as much oil as I could guestimate it would hold. Then squeezed some into the turbo its self. I cranked and cranked the car but it would never prime its self up.
Old Mar 9, 2004 | 05:23 PM
Bags's Avatar
Ahh, ok. Dixit mentioned to me cranking the car would not do it. I did not prime mine either. But I drove like an old lady and still am. SO I **hope** I am ok
Old Mar 9, 2004 | 10:12 PM
Julio's Avatar
[QUOTE=IceY2K1]White smoke is oil, right?
White smoke is water. An example would be headgaskets, where white smoke pours out of exhaust.
Blue smoke is oil, but can be mis-read as white if not in the right light or "at a funny angle."
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
A32goldylocks
Sep 2, 2015 06:39 AM
