hubcentrics but still vibrating... any ideas
hey i just put 18" MSRs on my ride and had a crazy vibration in the steering wheel over 46mph... we took all four off, rebalanced the wheels, put rings on all four hubs and made sure everything was real tight but I still have a side to side shudder over about 78mph... anyone have any ideas?
Originally Posted by 2k2nyc
Get a high-speed balancing
gotta be one of them Hunter machineswww.hunter.com
most machines can't handle anything over 17" and thus the balancing is off.
OT, but where in LI are u at?
I live in Holbrook but from Sept - May I'm in florida goin to school
wheels and tires were brand new so wear is out of the question and i guess the wheel could be bent but i'm not thinking so... the wheel goes left to right on every road, side roads, main roads, I-95, once i get up near 80.. you can actually see the steering wheel moving... it feels like the wheel is gonna fly off
i'll get an alignment and see what happens
this might be a dumb question, but are U sure the bore size of the hub is the correct size ? Hondas for instance have smaller hub bore sizes and will not fit. same with Toyota wheels. My friend installed a set of free winter Camry wheels on his 99 Galant V6 and he had all kinds of problems cause the wheels where not sitting on the hub correctly. I'll drive down to FL and fix that for ya
in order for aligment to do something like that, something has to be broken or bent. I do aligments myself on a killer Hunter aligment machine and I yet to drive a car that does what Ammi described. I've done some nasty aligments on body shop cars. Aligment will cause exessive tire wear, and pulls.. tires would have to point out or in BIG time in order for a vibration to happen. Check that the tires are alright, sometimes even a new tire can have a shifted BELT inside it and will cause a vibration. Try rotating the rears to the front ?
Bent wheels or suspension components can manifest themselves like a balancing problem.
I'm starting to wonder if another one of my (stock 17" alloy) wheels is bent... guess only way I could tell is by pulling 'em off and inspecting them closely (and rotating them while I'm at it--a bent rear wheel can cause vibration in the steering wheel, albeit subtle, but it becomes VERY apparant when you rotate them to the front... had this already with 1 wheel)
tarun900
19
Dec 20, 2021 06:57 PM
maxima297
Sep 30, 2015 03:32 PM
