Turbo sizing for automatic trannies..any different?
Old Mar 8, 2004 | 04:33 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I'm not sure exactly(which is why I'm asking)...but since the power distribution throughout the powerband is different, would it be optimal or would there be any advantages to sizing the turbo differently on an auto than say on a 5spd? I'm clueless as to whether it would make a difference, but was just wondering...any input?
Old Mar 8, 2004 | 05:19 PM
stephenlc's Avatar
With the longer gears you might want a turbo that peaks at a higher rpm to take full advantage of the longer gears.
Old Mar 8, 2004 | 07:30 PM
BigDogJonx's Avatar
There is an advantage on this, but it also depends on the torque convertor. If you have a nice high stall, you can launch at a good boost level where the 5spds will not.
But stock tq convertors i would not bother because after I did the 5spd swap im still seeing the same boost levels at the same rpms basically.
Dixit
Old Mar 9, 2004 | 03:08 AM
stephenlc's Avatar
If you get a high stall torque conveter that is around 3000 rpm and you have a turbo that gets full boost at 3000 rpm or a little higher you will have boost of the line. That is more of a drag situation and I wouldn't get a stall higher than 3000 because ti will start to affect daily driving.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
ef9
Oct 4, 2015 08:43 AM
