Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
white lines after waxing?
Old Mar 10, 2004 | 09:35 PM
DoGGy
why do i get white lines on my car after i wax? it looks like chalk or something. is it because i put too much wax or i didnt "buff " it in that good. im talkin about the corners and on side moldings and stuff. i washed the car and they didnt come off either. i had to manualy wipe them down. how can i prevent them from appearing when i wax my max next time?
Old Mar 10, 2004 | 11:30 PM
Bman's Avatar
Could you describe them a bit better? Are they actual raised lines of white residue, or are they just white-looking lines? Are they smeary or dry?
Old Mar 11, 2004 | 07:58 AM
DoGGy
they are dry. u know how u get calcium build up in ur kitchen or bathroom around the faucet. they look just like that.
Old Mar 11, 2004 | 02:35 PM
5 spd's Avatar
on flat surfaces or in between cracks and body moldings/lights?
Old Mar 11, 2004 | 04:17 PM
AscendantMax's Avatar
might be wax that didn't get buffed out during the buffing process. sometimes i'd would miss a spot when i'm buffing with my cotton towel, and it'll look like white streaks. next time when you buff, be more alert and go over all parts of the paint that wax was applied.
Old Mar 11, 2004 | 06:41 PM
CanadianMoFo's Avatar
Wax will do that when it gets onto rubber parts. I use painters tape to mask off all the rubber trim so I don't have that issue. Scrubbing the affected rubber parts down with Mothers Back To Black and a soft toohbrush should get rid of the stuff.
Old Mar 12, 2004 | 05:08 AM
endus's Avatar
An atavistic endeavor...
I think he means along the edges of panels and stuff like that...
It's just wax residue...nothing to do but buff it better. You can tape the moldings and stuff, but for the cracks you just have to be careful and make sure you buff thouroughly.
Old Mar 12, 2004 | 06:09 AM
Matt93SE's Avatar
STFU n00b!
for the spots you can't get to with the towel (between panel seams and stuff), I've used a SOFT toothbrush or Q-tip to get that stuff out before. just make sure whatever you use is soft enough not to scratch the finish and you're fine.
Old Mar 13, 2004 | 06:17 PM
foodmanry's Avatar
Da Roller Coaster!
Q-tips can and will actually scratch the paint. Even soft bristle toothbrushes will as well. The only brush you can use is one of horsehair. Or you can use a microfiber towel.
Old Mar 13, 2004 | 06:30 PM
I've used Q-tips without any problems
Old Mar 13, 2004 | 06:52 PM
As long as you change Q-tips after each pannel I can't see why they'd scratch.
Old Mar 14, 2004 | 08:57 PM
DoGGy
aight thanks guys. i need to buff it better i guess. waxing times time tho.
Old Mar 14, 2004 | 09:14 PM
yep, takes time, but the results are worth it
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
