Manual Tranny HELP!!!
Old Mar 16, 2001 | 11:46 AM
GTRBlkMax97's Avatar
How in the hell do you check the fluid in the 5-speed tranny on a 97 nissan maxima I think I might have tranny probs, I get a bad grinding when in gear only on right turns and straight not on left turns, anyone please help me
Old Mar 16, 2001 | 11:51 AM
Jeff92se's Avatar
I'm needing a caw
I would suspect a bad left or right CV joint. But to check the tranny level, jack up the car perfectly level and then unscrew the upper drain plug(for lack of a better word) It should either slightly drain out or if you stick your finger in there, it should be just below the drain opening hole.
Old Mar 16, 2001 | 11:54 AM
dch95's Avatar
Just in case...
check both of your cv joint boots to see if there is any cracks or if you have lost any grease (none should be visible). Although cv joints tend to make a clicking sound when they go bad, you can at least rule those out.
Old Mar 16, 2001 | 11:57 AM
well I just put in my springs and the cv boots looked fine is it possible they are bad and not have cracks or anything?
Old Mar 16, 2001 | 12:04 PM
dch95's Avatar
Hope you didn,t do what I did....
One time when installing NEW BOOTS, I must have phaucked up and got a hairline crack in my boot because about 2 weeks later I noticed that my rim was dirty as heel. I torn my MF BOOT!! Anyway, did you notice this noise after the spring install or was it allready there? If it happened afterwards, check to see if you pulled a dch95!
Old Mar 16, 2001 | 12:11 PM
kratz74's Avatar
Really no way to check your manual tranny fluid levels as Nissan intends it to stay put for the life of the vehicle. I put in Redline MT-L and notie a huge diff...
But unless you see leakage, your fluid is ok. The other members opinions about your cv, etc... sound on point.
Old Mar 16, 2001 | 12:14 PM
No it happend before the spring install, but will this help determine anything, it gets worse when it rains? you got me it is f@cked up.
Old Mar 16, 2001 | 12:24 PM
dch95's Avatar
Damm!!!!
that saucks!!!
Old Mar 16, 2001 | 12:39 PM
Daniel B. Martin's Avatar
Upper drain plug = fill plug
Originally posted by Jeff92se
... the upper drain plug(for lack of a better word) ...
It is called the Fill Plug.
Old Mar 16, 2001 | 03:29 PM
sleeper's Avatar
take it to the man..
i would get it checked right away, at the dealer , etc.,
Old Mar 16, 2001 | 03:38 PM
Jeff92se's Avatar
I'm needing a caw
Re: Upper drain plug = fill plug
Oh yeah. I forgot because I don't use that plug to fill the tranny anymore. It's too much of a pain. I just undo the speed sensor and use a long hose w/ a funnel. WAY faster and WAY easier. Espeically when you pre-measure the amount first.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
