Wideband O2 or EGT
Old Mar 19, 2004 | 07:53 AM
MardiGrasMax's Avatar
Wideband O2 or EGT
My APEXi EGT gauge broke. I am torn if I should get an new Greddy PHW gauge that will hook into my Profec E01 and data log for $205 or get a WB 02 set up for $310 frm PLX Devices http://www.plxdevices.com/onlinestore_domestic.htm . EGT will sort of show a lean condition and I really should have one with a turbo for heat build up. Wide band is just that AFR, it will log into the Profec E01 external input also.
Any thoughts?
Old Mar 19, 2004 | 07:58 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
the only thing that i would be wary of for the wideband is that it is a very sensitive o2 sensor.
you may have a little more wear and tear and have to replace the sensor more often.
Old Mar 19, 2004 | 08:14 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Auuuugh...how did it break? By itself?
I ask because I helped a friend install the same and it's no longer working. Just wondering if you did something or it died by itself.
Any thoughts?
Old Mar 19, 2004 | 08:23 AM
IceY2K1's Avatar
Any thoughts?
Old Mar 19, 2004 | 08:45 AM
Jime's Avatar
Any thoughts?
Matt, I have this one:
http://wbo2.com/default.htm
You can log with either a palm or laptop or watch the gauge.
If you just broke the EGT gauge you can also wire in the EGT sensor to the WBo2 and log the temps with it. I just run mine in parallel with the gauge so I can see both.
Mine was $390 with the readout etc but you can get it in different configurations.
BTW it uses the LSU 4 7057 wideband sensor available for $28 from VW. They are very durable but also inexpensive.
Old Mar 19, 2004 | 09:12 AM
BigDogJonx's Avatar
I agree with Jime, I got the same setup. Matt like I said on the phone, their DIY kit is about <$200. You can do full blown logging with your laptop. Map out A/F with RPM, and 3 thermocouple inputs as well as 3 other 0-5V inputs. But yes unfortunately it doesnt have an output where yo can feed it to your E-01.
Dixit
Old Mar 19, 2004 | 04:32 PM
Whats the better tuning tool?
I guess it would be better to get the WBO2 for now and tune the AFR a little leaner than the JWT is running using the EM, JWT has it at ~10.5:1 or lower according to the TTZ guys. When I start to crank up the boost over 13psi get an EGT to be sure?
Old Mar 19, 2004 | 06:41 PM
IceY2K1's Avatar
Honestly, with the J&S, keep leaning it out until you get where you produce peak tq.
With the J&S, it will show detonation and pull timing right? I'd keep going leaner until you trigger the J&S and then back it off a little. How far you want to go is up to you.
Any plans to dyno with the VQ30 setup?
Old Mar 19, 2004 | 07:20 PM
Bags's Avatar
VG Ridah's Biatch Hoe
sorry to jack your thread matt.. I thought More fuel = more TQ and less fuel = more HP
Old Mar 19, 2004 | 07:41 PM
IceY2K1's Avatar
To a point that's correct.
However, the way I understand it, you tune for peak torque throughout the RPM range. I could be wrong though.
Old Mar 20, 2004 | 05:02 AM
J&S will not protect against lean melt down. fust from runing too much timing advance.
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
Slamrod
Sep 3, 2015 07:38 PM
nigelcmf
Feb 25, 2002 07:38 AM
AllGo
Feb 20, 2002 10:28 AM
