HELP!! CLUTCH is leaking fluid
Old Mar 19, 2004 | 07:53 PM
Johnny01001's Avatar
here is the pic that my clutch is leaking fluid
http://www.angelfire.com/music5/shortyyanny/dammmm.jpg
Old Mar 19, 2004 | 08:43 PM
sryth's Avatar
Ok...that's your slave cylinder. Where exactly is it leaking from? The hose going into the cylinder? The pushrod?
Old Mar 19, 2004 | 09:00 PM
not the hose
i don't know if that is the pushrod or not
yuo see the picture where the tear arrow point at, is right there leak
Old Mar 20, 2004 | 11:50 PM
sryth's Avatar
The pushrod is the little **** that presses against the clutch-lever. It has a rubber acordian style boot around it.
Well, I can't see to well in the picture, but if it's not the hose, then it's most likely the piston seal.
If it ends up being the piston seal, you will either need to replace it or rebuild the slave cylinder.
Old Mar 21, 2004 | 04:51 AM
skiboarder72's Avatar
I have a leak too but i don't know where its coming from, the tank just drains down
Old Mar 21, 2004 | 06:31 AM
nismos14's Avatar
§è~® f®ÈÄk
skiboarder i would suggest checking ur hoses well, and figuring out where it's happening, otherwise you can get some very pre-mature clutch problems
Old Mar 21, 2004 | 10:59 AM
j_bryan's Avatar
i had a leak issue as well. i believe it was the hose from the master to the slave cylinder. once it was replaced, the leak was resolved.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
