Looking at a 2002 SE, anything to watch out for?
I'm going to go look at a 2002 Maxima SE, fully loaded with a 6-spd. I haven't owned a maxima or nissan before, anything to look for or watch out for?
Thanks in advance.
Mike
BTW, this will replace my 1991 Saab 900S.
Thanks in advance.
Mike
You won't be disappointed. The engine is bulletproof and the 6 speed is pure enjoyment. There were some early problems with the throwout bearing, Nissan opened a TSB (I beleive) and replaced it or the clutch.
Listen for a high pitched squeal as you engage the clutch.
Mass Air Flow Sensor should be 22680-AM600. If not, see if the car is under warranty and have the TSB performed to get a new MAF. The part number is on the MAF tube facing the front of the car. Take a flashlight (even during the day) and you'll be able to read the number. If it reads 22680-6N200 or 22680-6N201, you'll want to eventually plan to replace it. I can tell you how to replace it for under $100.
Also, check to see if the clutch "howls" when it's cold outside. Just rev the car up to about 1500 RPMs and slowly let out the clutch. Right when it grabs, if you hear a howling noise, know that the clutch needs to be replaced. If so, there is a TSB for that as well.
Other than that, it's a great car. Those are the 2 biggest things to watch out for.
Well we looked at it and drove it. Very nice, only a very slight shudder/wable while braking from high speed. Like I said, it's a 2002, SE, 6 spd, Silver with Black leather interior, navigation system, heated steering wheel, heated front seats, power front seats, Bose stereo with trunk mounted 6 CD changer, power sunroof, ABS, side air bags, 38,700 miles, clean Carfax report, one small door ding on left rear door. He's asking $19,750, agreed to $19,300. It's being inspected. Any thoughts?
Well it is loaded up. I love my 2k2 6 speed but it is a base model with only a sunroof and tinted windows. I'd be thrilled if I got within $2K of what your paying the dealer.
However, the car is great. Like others said have them perform all TSBs for free wince you are out of warranty. Those can add up to well over $1K in repairs. Biggest ones-throttle body and clutch howl.
By the way the 6 speed is not only fast when it wants but thrifty on gas. I get 30-33 mpg accd to the computer driving a constant 72 mph in 6th gear.
Also, I'm unclear about the TSBs. The dealer will do those for free even after the warranty is up? I couldn't see where the throttle body # was and didn't think I heard the clutch howl.
Thanks again, Mike
Thanks,
mike
What's the TSB # for the clutch "howl"? and is it covered under warrenty?
For TSB numbers, etc, visit:
http://maxima.theowensfamily.com/tsb/
Put in your year and you'll see all the TSBs for your car listed there.
Originally Posted by jeepdad
I'm buying it from a person, not a dealer, did I still get a good deal?
Thanks again, Mike
Thanks again, Mike
If the dealer can re-create the problem, then yes it will be covered under the regular 3/36k warranty. It is not covered under the powertrain warranty.
Our Maxima is beyond the 3/36k warranty. Is there any problems with waiting to fix the clutch "howl"?
I'd talk him down some more since the car is out of warranty (unless he's got extended). you'll encounter some TSB that need attention, if he hasn't had them performed already ....The steering wheel wooble/judder are the infamous warpped rotors....
Thanks again, Mike
Thanks again, Mike
Any recalls will be done free for the life of the vehicle. TSBs will cost YOU after warranty is up.
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
