Difference between Coil and MAF problem?
Old Mar 30, 2004 | 06:00 AM
nailz420's Avatar
What are some good signs on wether engine problems are ignition coils or MAF related? Ive read some threads and they site pretty much the same signs: rough idle, hesitation, low mileage,... Can someone sort them out?
Old Mar 31, 2004 | 01:59 PM
RobertYaz's Avatar
I'm a novice here, but I've just been through a coil problem and I'm investigating a separate possible MAF problem. Error codes would be the first tip-off. If a local Autozone will hook up a scan tool, you should get a P0100 for the MAF and a 1320 for coils. I definitiely had one or more bad coils, with two separate diagnoses. The coils were clearly a matter of intermittent rough running - as the coil cut out more frequently, the misfires became so bad the engine was shaking and the SES light would flash. It was more noticeable at acceleration (especially going uphill) when there's more stress on the engine than at idle. I parked the car for a week and ordered the coils. When I changed the coils this problem immediately went away and the SES light went out. Stalling in neutral or park persists - another problem. Maybe the MAF, as spark plugs were black indicating fuel and air are not mixing right.
Bob
Old Mar 31, 2004 | 04:23 PM
nailz420's Avatar
I saw some posts that indicated that MAF problem actually gives no codes in some cases where as coils always gives P1320. Well I guess i'll have to make an appointment at the Zone.
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
