my fun turbo troubles....
Old Apr 5, 2004 | 10:15 PM
mtcookson's Avatar
I just have a turbo from an 85-86 300ZX and it went bad. It was leaking oil into my intake and there was a bit of shaft play. I took it off to replace it with another 300ZX turbo that I had bought and I found the turbo to be worse than I had though...
Old Apr 5, 2004 | 10:17 PM
mtcookson's Avatar
I have it all fixed now but I'm still trying to figure out how they broke in the first place. I want to say shaft play bit I don't think the shaft moved enough to do that kind of damage so something must have went through the turbo to do this damage and I don't know how that is possible since I've never ran it with the air filter off...
Old Apr 5, 2004 | 10:28 PM
4signs's Avatar
hey did you ever think up upgrading to a t4/t3? Curious whats the A/R on the stock z turbo?
Old Apr 5, 2004 | 10:53 PM
mtcookson's Avatar
yeah, i'm planning on going to a t3/60-1 most likely but haven't really decided yet. i believe the a/r on the Z turbo is a whopping .46 or so on the turbine side. its terribly small for a 3 liter v6 but nissan didn't care about high output as much as they did low spooling for a better power band.
Old Apr 6, 2004 | 05:44 AM
Stephen Max's Avatar
Dang! How did the bits of compressor impeller not damage your engine?
Old Apr 6, 2004 | 10:44 AM
mtcookson's Avatar
I'm not sure if they did damage or not. I haven't noticed any power decrease but I'll still have to somehow check to see if they scraped the cylinder walls at all. Hopefully they didn't but most likely they did do a little bit of damage.
Old Apr 6, 2004 | 11:31 AM
Bags's Avatar
VG Ridah's Biatch Hoe
wow. looks like mine.
Did you check the turboi before you installed it?
Is there any damage on the compressor side?
Old Apr 6, 2004 | 11:35 AM
mtcookson's Avatar
When I installed it, it looked perfectly fine. I didn't notice any cracks or anything.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BobTX10
Oct 7, 2015 08:43 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Pixel
Sep 15, 2015 05:53 AM
