Tranny Slip, How Do I Tell?
Guys ... I'm getting worried ... cuz even for the 2K1 Maxes people are still talking about slippage of the Tranny ...
HOW do I tell if that is a Problem with mine?????
I really don't know how to tell!!!
if it slips...........then you gotta problem
Would ya mind posting the VIN #'s here??
I'm too lazy ... THANX!!!
Originally posted by UMD_MaxSE
Easiest first test: when was your car made and what is the VIN? check that out and compare with the TSB since it is a 2k1
It shouldnt be to hard. Just step on the all of the way and it go's.... VRRRRRRRRRR<ACCELERATING TOWARDS 6200 RPMS>RRRRRRRRRR<5500>RRRRRRRR<6000>RRR<6100>RRRR<6 200>RUMMM..... And it hangs at the "RUMM" part for a 1.5 second period. Good enough?
nice description of the sound but........
You or anyone else wouldn't happen to have a WAV file of this. Also when it slips dose the car stop pulling and just kinda make the sound of of reving up?? Because I took mine to the dealer and they said mine was fine but I know my car and it dose slip I think.
you will feel like it is put into neutral between shifts, so it wil rev but it wont shift and you left reving but no power touching the groudn, then it will eventually catch , the worse the slipping the longer the duration, that was ONE of my expirences
Is it supposed to be a delay or a thud. I have a delay and a thud when second engages, but only when cold(<10 miles). The thud isn't too bad, just like someone bumped into the back of your car at about 1 mph.
Good thing I read this thread....
Through reading this discussion I was able to determine that I too have the same problem my 2K SE Max. I just thought this was something normal with my automatic Max. I have never had an automatic car before, so I figured that was a delay inherent to the auto tranny. I should have known that is not normal based on the delay in shifting from1st to 2nd.
Anyway, called in my car for service at the local Nissan dealer and they scheduled me in in two days!
For those of you not sure if it's happenning with your car, it is rather easy to tell: gas it off the line, if it hessitates (revs without shifting) from 1st to 2nd for about a second - you've got a problem.
We'll see what the dealership tells me and what they do about it...
Re: Good thing I read this thread....
Dealer replaced the speed sensor which is the culpret. It's better but not the best. It's my first Automatic and I just close my eyes as the tach reaches 6.5k and shifts.... barely.
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
