4th gens with 20s what size tire are you running?
i use the newest (smallest) tire size which is 225/35/20 which is about .6" bigger than stock..however the more common sizes are 245/35 and 255/35 which will make your car sit noticably (almost 2") higher than stock
A 245/35 and 225/35 are the same height, the only thing changing between them two are the widths! first#=Width second#=sidewall height. I personally have 245/35/20's and Im using maxspeed springs. The front rubs when you make sharp turns but it also rubbed without the springs in so...
A 245/35/20 has these specs:
Sidewall: 3.4in
Radius: 13.4 in
Diameter: 26.8in
Circumf: 84.0in
Revs/Mi: 754.0
Where as a 225/35/20 is MUCH different:
Sidewall: 3.1in
Radius: 13.1 in
Diameter: 26.2in
Circumf: 82.3in
Revs/Mi: 770.0
Understand now? Changing width does a LOT.
Originally Posted by Xplayboy69x
we put my 20's on a 4th gen with sprints with 255/35/20 they scrub in the rear, you would prolly want to do 245/35/20
Finkle
Sep 27, 2015 09:53 PM
