4th gens with 20s what size tire are you running?
Old Apr 14, 2004 | 08:39 PM
96shogunmax's Avatar
And what suspension setup? Just curious about how big of a tire will fit.
Old Apr 14, 2004 | 09:17 PM
wope's Avatar
i use the newest (smallest) tire size which is 225/35/20 which is about .6" bigger than stock..however the more common sizes are 245/35 and 255/35 which will make your car sit noticably (almost 2") higher than stock
Old Apr 15, 2004 | 02:02 PM
Seyser's Avatar
A 245/35 and 225/35 are the same height, the only thing changing between them two are the widths! first#=Width second#=sidewall height. I personally have 245/35/20's and Im using maxspeed springs. The front rubs when you make sharp turns but it also rubbed without the springs in so...
Old Apr 15, 2004 | 02:06 PM
1FSTMAX's Avatar
Wrong forum buddy...now sell me your ECU and VI.
Get some 235/30/20
Old Apr 15, 2004 | 02:54 PM
formz
When you change widths you also change rolling diameter.
A 245/35/20 has these specs:
Sidewall: 3.4in
Radius: 13.4 in
Diameter: 26.8in
Circumf: 84.0in
Revs/Mi: 754.0
Where as a 225/35/20 is MUCH different:
Sidewall: 3.1in
Radius: 13.1 in
Diameter: 26.2in
Circumf: 82.3in
Revs/Mi: 770.0
Understand now? Changing width does a LOT.
Old Apr 15, 2004 | 06:16 PM
I got sprints and I rolled a 255 up to it and it was TIGHT. the 245 was also tight but i think it will go. anybody got sprints and 20s?
1FSTMAX - $598489524895.99
Old Apr 15, 2004 | 06:17 PM
Seyser's Avatar
Sorry my bad! Thanks for the correction!!!
Old Apr 17, 2004 | 11:37 PM
white m3 guy's Avatar
we put my 20's on a 4th gen with sprints with 255/35/20 they scrub in the rear, you would prolly want to do 245/35/20
Old Apr 18, 2004 | 08:24 AM
So they do rub on oss's car. I will probably do the 245s then. Thanks.
Old Apr 18, 2004 | 07:49 PM
well i think he springs in the rear are cut too though
Finkle
Sep 27, 2015 09:53 PM
maximaham
Aug 20, 2015 10:23 AM
mls277
Aug 11, 2015 07:18 PM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
