Do our auto trans have a pressure sending ports ?
I'm reading about how grand prix installs transmission temperature gauges and I was wondering if we have a pressure sending port on our transmission that we could tap as well. I want to put a transmission temperature gauge on my car because I'll be towing.
Here's the link to see what I am talking about on the grand prixs.
http://www.grandprix.net/upgrades/transtempgauge.html
It's on that second picture.
Thanks.
Thanks.
Originally Posted by SamMan23
I'm reading about how grand prix installs transmission temperature gauges and I was wondering if we have a pressure sending port on our transmission that we could tap as well. I want to put a transmission temperature gauge on my car because I'll be towing. Here's the link to see what I am talking about on the grand prixs. http://www.grandprix.net/upgrades/transtempgauge.html
It's on that second picture. Thanks.
MIKE
there are "plugs" on the side of the tranny - remove the driver side wheel & splash guard you"ll see them right in front of you. Thy look like engine plugs - ( i hope that you get the idea )
I'm not sure on how to remove them though - my local dealer did pressure testing recently.
Nick.
Nick.
Thanks.
Thanks.
tell me about the installation into the oil pan. I'm thinking it may be difficult to get the threading right for the pressure port because it's probably metric threaded. Did you need a tap and die set to drill the pan?
Nick.
Nick.
Thanks.
Thanks.
Originally Posted by MaximaGTR34
Do you guys think it would be more ideal to get the sender into one of these plugs versus having to put a hole in the tranny pan? I've got my trans gauge sitting here in front of me, but still trying to figure out just exactly where to place the darn sender
I did intall a tranny cooler. It seemed to have done well. I only got 15 mpg though. It was probably somewhere between 1500-2000 lbs. from san antonio to houston. next tow will be from houston to atlanta.
Originally Posted by charliekilo3
That seems like a lot of weight for a Max to pull behind it. If it was a taller than the car, I could see how the wind resistance would cause your car to work much harder pulling the trailer. I looked in my owner's manual and the maximum trailer load for my 02 is 1000 lbs with a max tongue load of 110 lbs.
Yes. You are right. The specs for this car is 1000 lbs. The factory specs are always much more conservative. I have a 98 with the 3000cc motor. The same engine and I think same transmission is also speced to pull 3500 lbs on the Nissan Quest. The engine is fully capable of pulling a properly loaded 2000 lb trailer. Driving it and making sure you have enough stopping distance is where it gets tricky. The brakes on this car is not meant to stop such a heavy load. You also have to make sure that the transmission does not have to shift often. This is where most heat is generated during towing. If it hunts for gears then you need to drop out of overdrive and slow down.
