7500 mile checkup... time for synthetic oil?
Hey guys, I'm just about at the point where I need to go in for my 7500 mile checkup.. can I just call up the dealer and say "hey, I need to schedule a 7500 mile maintenance for my car"? Also, is it time for synthetic oil? If so, which brand do ya'll recommend?
Thanks....
Thanks....
I did an early break-in oil change at 1500, then again at about 4500. I switched to Amsoil synthetic right about where you are now, 7500 miles. I figure I can stretch the intervals to 5000 miles now. Amsoil and Redline, I believe, are the only TRUE synthetics on the market.
Nothing scientific, just the way I did it and I chose Amsoil because I use it in my Powerstroke.
Call up the dealer and schedule the appt! I need to do the same to fix some small issues like;
Glove box door not aligned
Trunk entry switch on door not working
Heater blows when off
SES light comes on from time to time
Originally Posted by Phatmax98
What's the point of switching to synthetic so early? You really don't even need synthetic until approximately 100,000...synthetic is generally used on high mileage motors
Originally Posted by Monotaur
Well, I've heard/read that it is easier on the engine and will also improve gas mileage by 1 or 2 MPG.... I know a guy that has an 02 Altima and after switching from the generic dino oil used at the dealership to a synthetic, he got another 2 MPG... same with his Toyota truck. Am I completely off base here?
I believe that is true about the gas mileage, keep in mind that once you switch to synthetic it's recommended that you don't switch back. You can also use a thinner regular oil instead of switching to synthetic...unless that is what you truly want to do. Like, use 10W40 in the summer and 5W30 or 10W30 in the winter. Next time you get your oil changed at the dealership or someplace with a good rep, ask them if you should switch. Unless you do it yourself. Hope this helps.
Originally Posted by hofb99
Dude! EVERYONE'S glove box door is misaligned! It's inherent of the 6th Gen! lol Sorry...
Synthetic oil reputedly has better lubricating properties, hence slows engine wear to some degree. It also has properties that can enable an engine with high mileage to continue to give satisfactory performance.
I certainly accept that an engine using synthetic oil should get slightly better gas mileage; probably between 1% and 3% better. That is a meaningful improvement, and, coupled with longer engine life, speaks well to the advantages of synthetic oil.
But 2 MPG improvement is more than I feel would be realistic. At 25 MPG, a 2 MPG improvement represents an 8% improvement in fuel economy. That is a very huge improvement that I would be hesitant to believe can be accomplished simply by switching to a synthetic oil.
But I haven't run the tests that would be required to prove this.
Amsoil 0W30 is an excellent oil for 5W30 and 5W20 engines. I use it in 5 family cars between 1 and 5 years old. They all were quieter after the switch. I also will run Amsoil for 5 to 7 K miles or about 6 months of driving.
The engines also consume less of the synthetic oil than they did with mineral oils.
Lots of reviews on the web. One good spot is SVTPERFORMANCE.COM for Cobras, Lightnings and Focus hot rods. A contributor named Cobra'03 is an oil expert who posts great tips and leads.
And, I use Mobil One oil filters because of their high quality, and they are readily available locally. I would use Amsoil filters but I didn't want to stock up on them, then decide to switch cars.
MatthewsMaxima
Sep 11, 2015 03:21 AM
