HID in Fog Light Problem
Old Apr 24, 2004 | 05:07 AM
titot4u's Avatar
I'm having problems installing HID's on my 2k1 fog lamps. Everytime I place the H3 bulb in lamp and turn the HID's on, I get a ticking sound and lights won't come on. I believe the bulb itself is touching the metal inside the lamp causing it to short and not work. Has anyone with a 2k-2k1 have success installing HID's in fog lamps? If so, what procedure did you use?
Thanks,
Tito
Old Apr 24, 2004 | 05:55 AM
† ErV †
it's probably a ground issue or a defective kit. have you tried the kit with the bulbs outside? like just put them on a bench and test them with a 12v source.
Old Apr 24, 2004 | 06:01 AM
Igor911's Avatar
yes it is touching....u need to stick a screw driver inside the foglight and push the reflector forward just a little bit.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
