*2 Vids* Is this normal y-pipe noise???
Old Apr 26, 2004 | 12:35 PM
ScarfaceTHX's Avatar
Taken with a 2 megapixel canon powershot...
This is me turning out of my neighborhood and flooring it up a very big hill. (Newnan crew can verify this heh). You can barely hear it in this vid. It is the high pitched noise after 3000rpm in first gear and then a little bit on the 1-2 shift:
http://www.auburnextremeracing.com/d...pipe_noise.avi
OK this vid sucks but you can hear the y-pipe noise very clearly. Same rpm range and also at 1-2 shift:
http://www.auburnextremeracing.com/d...e_se/ypipe.avi
...And before someone tell me to fill up:
-Knowles
Old Apr 26, 2004 | 01:03 PM
Maxima99SE's Avatar
will fly for food
yah that is a big hill-- havent seen that side of newnan in quite a while... as for the noise... that's really weird.. i wanna hear it in person
Old Apr 26, 2004 | 01:10 PM
Tyrexx's Avatar
I dont hear anything wierd...........
Old Apr 26, 2004 | 01:28 PM
Maxima99SE's Avatar
will fly for food
tyrexx, i had to listen to the video a few times to start hearing it.. but it stands out a good bit now that I've heard it a few times
Old Apr 26, 2004 | 05:11 PM
Torgus's Avatar
at what seconds do you hear it in the movie? can you describe the sound?
Old Apr 26, 2004 | 06:34 PM
at the very beginning of both clips when the car is haeding towards redline
the sound is alomost like something is loose - there is metallic sound... whether it is exhaust leak and pipes or banging or if the valves are tapping idunno
if you have a set of headphones there is no way you can miss the noise
if this helps... listen for any noise other than intake GROWL ....sounds like something is coming loose is the only way i can descibe it
i know it's not the best quality sound. I really need to set up my tripod and real camera and get some outside shots
that way i could tell real quick if it's header leak or valves or nothing at all
Old Apr 26, 2004 | 06:47 PM
happyricefob's Avatar
V^___^V
1. remove headshield above your flex section to the b-pipe
2. remove the prongs off near the y-pipe supporter
3. cut off the cross member that is almost touching the flex section
4. get exhaust wrap and wrap your flex section
Old Apr 26, 2004 | 07:23 PM
Torgus's Avatar
ya what he said. if your buying header wrap you might as well wrap the whole darn thing imo.
Old Apr 26, 2004 | 07:28 PM
SuperFishstick's Avatar
wow.. $1.89 for premium.. I got to pay $2.20 here
Old Apr 26, 2004 | 08:05 PM
So basically look and see if the y-pipe could be hitting anything?
I was going to do the header wrap regardless but it sounded so quiet except first gear.
Old Apr 26, 2004 | 09:22 PM
Ant96GLE's Avatar
Sounds like the Y pipe is hitting the catalytic converter heat shield. Get under there and give it a few shots with a hammer and bang it out the way. Mine did it, it sounded like a loose piece of metal banging around.
Old Apr 27, 2004 | 02:24 AM
WillMax95's Avatar
i use plus, still about 1.60 here
Old Apr 27, 2004 | 03:15 AM
RastaManMax's Avatar
I still can't hear anything abnormal. It sounds like you have intake and y-pipe?
LEMAR
Old Apr 27, 2004 | 03:36 AM
egxflash's Avatar
2.39 here
Old Apr 27, 2004 | 06:25 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i dont hear anything either ? i know when i have had trouble with my exhaust knocking around it is real loud, not sure on this one ?
Old Apr 27, 2004 | 06:56 AM
Brudaddy's Avatar
Sounds pretty normal to me.
Just a good growl.
Old Apr 27, 2004 | 09:28 AM
ShRapNeR's Avatar
Its not safe to drive that fast wet roads
but none-the-less my pipe done the same thing..... except i took it to the exhuast shop since im not very good w/ mechanics / i can't fit under my car?
they told me that it COULD NOT be where the y-pipe meets the cat converter its just too stiff (i argued for the longest) ,, but when they removed the old pipe a couple months ago it was attached to this clip between the front wheels... they cut part of that off and it reduced it a bit..
still makes the noise.. just not as much......
so i don't know what it could be................... they told me it was prolly the hose clamp i put on my b-pipe hanger to keep it from hitting that bar thing..
ive removed the headshield from the cat - b-pipe
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Quickywd01
Sep 21, 2016 09:36 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
