Is disconnecting the battery the same as resetting the ecu?
Old Apr 28, 2004 | 01:39 AM
DaBombX's Avatar
If i disconnect the battery and let the car sit for a while, will the ecu still remember the old codes?
What's the difference between clearing your code and resetting your ecu?
Old Apr 28, 2004 | 02:25 AM
C MAX's Avatar
no you can't reset it like that. resetting, clearing is the same thing you have to either manually reset with a screw driver or with a scanner.
Old Apr 28, 2004 | 10:15 AM
SzeMan4's Avatar
yea C MAX is right. My buddy just went to autozone and they reset it for free.
Old Apr 28, 2004 | 10:36 AM
Pearl99GXE's Avatar
I have to disagree with the other two.
If you leave it disconnected long enough (like over night) it will reset. Any CEL and get rid of any codes.
Old Apr 28, 2004 | 11:09 AM
C MAX's Avatar
you could only do that with the later yrs. i tried that already don't work.
i had my battery disconnected for 2 mths while my car was in the shop
and when i put the battery back in the light was still on. if this is true i apologize for the mis-info
Old Apr 28, 2004 | 11:17 AM
I30tMikeD's Avatar
disconnecting the battery over night worked for me.
Old Apr 28, 2004 | 11:35 AM
Brudaddy's Avatar
I don't think they are the same thing. Resetting the ECU clears the codes.
disconnecting the battery causes the ECU to read everything like it is a new thing. It starts learning instantly.
Old Apr 28, 2004 | 11:46 AM
97SEMAXI's Avatar
its not the same on '97s, i had my battery unhooked over night and the sel was still on, it only takes like 3 minutes to reset the ecu anyways, might as well do that
Old Apr 28, 2004 | 02:17 PM
DaBombX's Avatar
Well, I cleared my codes and new ones haven't showed up.
I guess I'll just wait... I mean, the ecu is gonna learn again sometime or another, right?
I wonder how long it will take.... (to adjust to KS and intake)
Old Apr 28, 2004 | 02:21 PM
mansurxk's Avatar
well my quetsoin to you guys is, shouldnt the light come back if something is wrong regardless of leaving it off for an hour or 2 months? if it sensing something wrong even after being reset when you start the car, itll show a code, but if you replace lets say an O2 sensor and then take off the terminal for a few hours, will the CEL still stay lit?
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
