Which springs with stock struts: Max H tech Prog
I need to get rid of the wheel gap but Im saving for summertime 20s so money is tight. Which spring is the best to run with stock SE shocks/struts for about a year until I upgrade to gr-2s Maxspeed, H-tech, or Progress, also I want a level drop that wont rub with 20x8.5 Diablo Lionharts...not sure of the offset. I also have two 12's in the trunk so the rear is wayed down about 75 lbs.
Thanks in advance for the advice.
H&R - You'll want the least extreme drop to make your stockers last as long as possible. Also, with 20's, the ride will be much stiffer - the H&R's offer the best ride of aftermarket springs.
More info: http://www.innerbean.com/housecor/sp..._decision.html
Originally Posted by Shift_VQ
do you have any pics of your setup?
dank4us
34
Jun 10, 2024 03:45 AM
Justin Kroll
Sep 2, 2015 11:06 AM
