How tos? HOTSHOT header?
Does anyone know where i can get information on installing the hotshot headers on 03s? i just found out today that u have to drill holes for the O2 sensors.. any info would be appreciated.
Originally Posted by harmbone2k2
first thing is first...your hands must be made of titanium!!!!!
Or.... U can leave the bungs out, get some 02 sensor eliminators and let the 02s hang somewhere where they won't touch anything or get destroyed- mine sits under the cover on the valve cover. The eliminator is basically a resistor that fools the computer into thinking the cats are working. If U have a cat- then it will be fine, if U don't have a cat then the 02 sensor eliminator is needed eighter way- I used to get Check engine lights every 4 days with my style of driving cause of no Cats.
Originally Posted by Martin F.
were do you get the 02 eliminator?
http://www.o2simulator.com/
This wouldn't be the same on a 2000 fed would it. I am trying to see if I can put them on my car. looking at the headers they got a O2 sensor at each header. Mine only has three O2's right one on each manifold and after the main cat.
With that you won't have to do any relocating at all just plug in the two that were on your stock manifold into the headers and leave the other where it is.
The problem with the 3.5's is that there are 2 before the precats and 2 after on the stock manifold so the 2 rear ones have to be relocated after the main cat after the precats are removed.
Mick, the guys with headers and stock exhaust have reported that the sound level is very tolerable and actually quite nice sounding...350z ish. My setup on the other hand is pretty loud.
and with all the posts going on asking for header how-tos there obviously isn't one.
not something every person is willing to do, taking pictures while taking about the car and various components for a 4-6 hour installation. not enough ppl are running headers (15+?) on the board yet.
Originally Posted by ajsince81
Is there any negetive effect on using o2 eliminators on a 2002? Could it be harmful to the car at all?
If you don't care about the light being on then don't waste your $25 on the eliminator.
I want to know if the cel is on and why so I chose to use the o2 eliminators.
Originally Posted by BlackBIRDVQ
BTW I done a write up on how to install headers on the 5th gen forum here.... like a week ago or so.
KabirUTA13
19
Oct 17, 2015 02:15 AM
