Best pads for slotted rotors...
I just bought a full set of slotted Brembo rotors and was wondering what are the best pads for these rotors. Im thinking about Raybestos Quiet Stops or EBC green stuff pads. I am currently running Stillen cross/drilled rotors with Metal Axxis pads and they are squealing alot. I want something with less dust and no squealing. Can anybody with experience with this kind of setup help me out? BTW if it helps any imma 4th gen, THANX.
-WILL
-WILL
nismo, these brembos are gold right, i want to get some but didnt know about the gold color, you think after repeated breaking the gold will wear off ?
also do you have them yet, i wanted to make sure they are 9.8 lbs and same as stock dimensions.
sorry about the OT
link:
http://maxmods.dyndns.org/index.php?MaximaBrakePads
sorry about the OT
link:
i'd go with the ebc greenstuff, but if you can get the raybestos for cheaper... might as well go for those. not a considerable difference IMO
ceasar: i believe the stillen ones are gold plated, the brembos are usually zinc or cadmium (sp?) plated. They will wear off where the pad makes contact with the rotor. However everything else will stay the same.
sorry about the OT
link:
sorry about the OT
link:
-WILL
-WILL
Lo-Tse
I've used the Axxis pads on all my vehicles, either it be a daily driver beater or a weekend track car, and have never had squeeling problems. If you're having excessive noise, it's most likely due to improper installation and/or break-in of the pads.
If you decide to replace the current pads, make sure you apply sufficient brake grease on the shim and backside of the pads and clips. Also make sure to break in the pads properly to prevent any glazing or uneven wear.
Apr 16, 2020 05:15 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
