How Do You Remove The Door Trim?
pull the trim around the handle off, theres a screw under a cap at the bottom of the hole in the armrest, pry out the window switch, then gently unseat the christmas tree clips that hold the panel to the door, starting from the bottom. When they're all out, hold the panel with the bottom away from the door and pull straight up to get the top out of the sill.
Remove the OUTside trim from the INside of the door. This requires removing the inner panel as 1991tsi explained... and peeling away the plastic vapor barrier... then you will see the backside of the clips holding the trim to the door....
Cheers!
Cheers!
James92SE
142
Jan 2, 2024 09:23 AM
carid
Sep 17, 2015 05:00 AM
brichi
Sep 14, 2015 05:23 PM
