Problems on rear O2 sensor & Power antenna!
Old May 13, 2004 | 04:33 AM
hellochen's Avatar
Vehicle: 95 Max
Rear oxygen sensor:
Can I buy a 3-wire universal sensor and fits it into my car?
What type of univeral sensor has the same output signal with the one in 95 Maxima?
Power antenna:
I have to replace my broken power antenna.
There are some non-OEM power antenna but much cheaper,how can I tell whether it could be installed in my car without problem?
Is the installation process complicated?
Here is a website for antenna:
www.antennax.com
Could you please tell me if the power antenna fits my 95 Max well?
Thank you very much.
Old May 13, 2004 | 05:47 AM
Dubbya's Avatar
VK56 Inside
Check this link for the antenna install. Its pretty easy.
http://www.carstereohelp.org/DoItYou...ssanPwrAnt.htm
Old May 13, 2004 | 05:49 AM
joeynym's Avatar
Back in the Max
i can help with o2 sensor, i just changed my 2 front ones, i used universal on both, check eng lite still came on, went to pep boys & gotthe bosch factory ones & they worked perfect...... the ones that pep boys carries is bosch & the old factory ones are bosch too, so dont waste your time or money on universal ones.......... good luck
Old May 13, 2004 | 06:10 AM
njmodi's Avatar
Do I get a tax break?
Neat link. Just an FYI - I bought a replacement antenna mast for my 96 GLE for 14.99 at a local Pep Boys.. so you may want to try pick up a part locally and then follow the instructions on website Dubbya provided..... let me just say this - I really had to muscle the old mast out of the antenna housing - it just wouldn't give. I eventually got some pliers, and twisted the old mast out... don't be scared to use a little strength when twisting the old mast... it will break free eventually.
Cheers,
Old May 13, 2004 | 08:18 AM
THT's Avatar
THT
Throbbing member
I use Walker OEM sensors for simplicity's sake. Unless $20 will break the bank, I suggest going with OEM as you won't have to mutiliate the harness.
~THT
Old May 13, 2004 | 08:45 AM
njmodi's Avatar
~THT
Yes. I also recommend getting OEM harness equivalent sensors... I would suggest the Bosch as suitable replacements, since Bosch manufactures the actual Nissan part to begin with...
<Edit> removed useless info. about FRONT sensors - since the original question was about the REAR sensor.
Nirav
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxinout93
Aug 20, 2015 02:17 AM
