Problems on rear O2 sensor & Power antenna!
Vehicle: 95 Max
Rear oxygen sensor:
Can I buy a 3-wire universal sensor and fits it into my car?
What type of univeral sensor has the same output signal with the one in 95 Maxima?
Power antenna:
I have to replace my broken power antenna.
There are some non-OEM power antenna but much cheaper,how can I tell whether it could be installed in my car without problem?
Is the installation process complicated?
Here is a website for antenna:
www.antennax.com
Could you please tell me if the power antenna fits my 95 Max well?
Thank you very much.
Rear oxygen sensor:
Power antenna:
www.antennax.com
Check this link for the antenna install. Its pretty easy.
http://www.carstereohelp.org/DoItYou...ssanPwrAnt.htm
i can help with o2 sensor, i just changed my 2 front ones, i used universal on both, check eng lite still came on, went to pep boys & gotthe bosch factory ones & they worked perfect...... the ones that pep boys carries is bosch & the old factory ones are bosch too, so dont waste your time or money on universal ones.......... good luck
Cheers,
Originally Posted by THT
I use Walker OEM sensors for simplicity's sake. Unless $20 will break the bank, I suggest going with OEM as you won't have to mutiliate the harness.
~THT
~THT
<Edit> removed useless info. about FRONT sensors - since the original question was about the REAR sensor.
Nirav
kjlouis
11-24-2018 06:09 AM
vingodine
45
05-21-2016 12:46 PM
Huttig2009
09-25-2015 03:31 PM
maxinout93
08-20-2015 02:17 AM
