Question about pulled code
Old May 15, 2004 | 06:46 PM
hacim105's Avatar
I just got a 01-11 which is "evap control system/flow." Has anyone else received this code? How did you fix the problem?
Also my friend's maxima's driver side rear brakes is stuck clamping onto the rotor. How do we fix this problem? Any possible reasons why this is happening?
Thanks for the help.
Old May 16, 2004 | 02:48 AM
Jay93SE's Avatar
Ist Q: Don't know.
As far as the brakes, the caliper piston may be seized, or the pins that the caliper bolts to may be seized.
Old May 16, 2004 | 03:27 AM
Kevlo911's Avatar
Kevlo for President
0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
mvm062
Nov 30, 2020 09:00 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
