give me some advice on this problem!!!
Old May 18, 2004 | 09:10 AM
dj4eign's Avatar
so i have a prob with my steering. when i get on the gas on the highway, i feel the steering get "loose" n pull the opposite direction. real violently too. even if im going aroun corners, if i squeez the gas alittle it it pulls to the opposite direction i've noticed it gettn worse and stronger. almost made me loose control the other day. even when the car is backn up or just turning the wheel, i hear a clank that seems to be comming from the drivers side. sounds like somthing is loose. even if i go over a small pothole or uneven road i hear it n the steering shifts from pulling one way to pulling to the opposite way. now i know i have to do my steering rack n pump, would this have anything to do with it? someone pliz help out!!!!
Old May 18, 2004 | 11:22 AM
MaximamixaM's Avatar
How many miles? What condition is the rest of your suspension in?
Old May 18, 2004 | 11:50 AM
Jeff92se's Avatar
I'm needing a caw
Um take it to an repair facility TODAY. You got something broken under there. ie.. tie rod, ball joint, control arm bushing is blown out. Strut mount is broken, conbination of anything above.....
Old May 18, 2004 | 12:27 PM
90SEBlack's Avatar
Nope its your Lower Control arm bushing Im POSITIVE theres no real way to fix it cuz no one sells them u can try getting one from interautometer but i dunno if it is exact fit, (Here comes the best part Jeff) I made one out of aluminum to take the place of the rubber but it creates road noise but stops the clunking and keeps the car tracking straight if i find a solid fix ill let you know, Im trying to fabricate something out of a 1996 Cutlass Control Arm bushing.
Old May 18, 2004 | 12:29 PM
Jeff92se's Avatar
I'm needing a caw
Um wow. But Kaleb at Courtesy Nissan already sells new Nissan bushings. Matt93se pioneered the replacement bushing replacement about 2 years ago vs replacing the entire control arm. I think there is poly bushings available also.
Old May 18, 2004 | 12:30 PM
90SEBlack's Avatar
Whats his number
Old May 18, 2004 | 04:00 PM
internetautomar's Avatar
mod or sell?
The poly bushing used are from a 4th gen.
The "bigger" bushing does require some "adjustment" to make it work though
yes I sell those too
Old May 18, 2004 | 04:06 PM
dj4eign's Avatar
Ok I'll get that checked tommorrow. I got a new motor in there but the body just hit 180k. Runs great. U know what's funny though, in the winter I blew my tranny n when I did the passenger front side was slammed like I had lowering springs but only on the front passenger side. After I got the car back, it was all set. Never happened again. What u think that was? And jeff, u know how much those bushing cost to get put in or to purchase
Old May 18, 2004 | 09:12 PM
dewmax007's Avatar
Dude, start with the ball joint! just replaced my struts and found a very bad ball joint which made the car launch into on coming traffic when hard on the gas...also had a loose swaybar mount which accentuated the problem. I don't doubt the your control arm bushings are shot as well but start with easier fixes first.
Old May 19, 2004 | 04:53 AM
drstillpatient's Avatar
if you hear a clunk upon accelerating and deccelerating, it would be a bad ball joint. if u dont hear anytthing btu the car still pulls to the side suddently, check the control arm bushing. just have em both checked .
Old May 19, 2004 | 06:21 AM
mod or sell?
Buy a control arm complete with ball joint
Old May 19, 2004 | 06:38 AM
89badmaxse's Avatar
i got some lower control arm bushings from my local bumper2bumper store they were the only ones who had them and it was recently maybe you can try there there is also a place near me calle automotive engineering who carrys parts like that look them up on the internet and give them a call they ship they are in clearwater florida off of us 19 you can try that if youd like.......
Old May 20, 2004 | 09:48 AM
dj4eign's Avatar
Thanx. U guys been a big help. Appreciate the love.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
markevans999
Sep 10, 2015 04:29 PM
flu2000
Sep 8, 2015 02:23 PM
