Rearveiw mirror shake.
Old May 19, 2004 | 09:43 AM
Slow Moe's Avatar
Hopefully this dosent sound too stupid.
Anyone try to Dynamat (or any other sound deadener) the rear veiw mirror to keep it from shaking.
Old May 19, 2004 | 01:51 PM
slickrick's Avatar
its not dumb but where would you put it exactly?
Old May 19, 2004 | 02:28 PM
MannyNJ2k2max's Avatar
My rear view vibrated with my non bose OEM system.....
Old May 19, 2004 | 04:08 PM
OneToughMax's Avatar
if you use dynamat extreme and put it on the back of the mirror, it would reflect sunlight and blind oncoming drivers
Old May 19, 2004 | 07:48 PM
87MustangGT's Avatar
Not sure how the newer Max's are set up, but on my third gen the rearview is mounted by a bracket to the roof, but has a little rubber thingy that goes between the bracket and the windshield... When I had the rubber thing out when I got my tints, the mirror shook like crazy, but it all but stopped when I put the rubber thingy back in...
Old May 19, 2004 | 09:27 PM
Slow Moe's Avatar
I was thinking to spray paint the dynamat extreme black and in a straight strip right across behind the mirror.
Old May 20, 2004 | 02:10 PM
slickrick's Avatar
hmm. i need to something about this also. mine is rattling real bad now in the day time due the bass/heat and im afraid its gonna slit the mirror in half. i dont think anything will ever stop the rattling completely because i can put both hands on it and hold it, but it will still move a little.
Old May 20, 2004 | 09:59 PM
HitManSE's Avatar
You guys complain too much! What the hell am I supposed to say about my mirror
Mine actually starts to move and face down after I play a track longer then 1min
Old May 21, 2004 | 06:40 AM
Kojiro_FtT's Avatar
That will do nothing. Dynamat does not form some kind of sound proof spacial anomoly, preventing sound just by it's presence alone. The mirror will still shake.
If you really want to do something, you would need to figure out how to tighten down the joint that allows the mirror to be moved. And of course once you do that, you won't be able to adjust your mirror anymore. Even then, it would probably still vibrate some.
Old May 23, 2004 | 08:09 AM
MarpsI30t's Avatar
what about trunk and spoiler rattle?? has anyone used dynamat or something like that to fix??
Old May 23, 2004 | 12:18 PM
HitManSE's Avatar
Got both shaking, its pretty much impossible. Only option is to take it all apart, go overkill on the sounddeadner and hope it works after you get it back together. Id say, just turn it down a bit...although I can understand how difficult that can be
Old May 25, 2004 | 04:22 AM
01_blue_max's Avatar
mine too
Old May 25, 2004 | 05:18 AM
guysohigh's Avatar
SimStones
Horrible
This is the 4th car i've had a system in, and by FAR has the worst mirror shake. I can't even look at it because the moment i adjust it, and a good song comes on, it shakes right back, and i'm looking at my backseats through my rearview. Is there really no fix for this???
Old May 25, 2004 | 06:33 AM
HitManSE's Avatar
Do what I do...look at the rear veiw between beats
Old May 26, 2004 | 03:41 PM
image's Avatar
my mirror flaps like a ****ing bird. It goes everywhere. just ignore it!!!!! That means you got good bass!
Old May 27, 2004 | 08:22 PM
TonyMaxNismo's Avatar
You guy's are lucky that your mirror is only dancing to the beat.....my mirror broke off from the bracket and replacing it would of cost me 600 bucks but since I have tinted windows...I bought the mirror without the auto dim.
Old May 27, 2004 | 08:31 PM
AscendantMax's Avatar
600 dollars?! damn!
Might be just me, but with my Broadway mirror on, it seems to shake a bit more. With only the stock mirror, it doesn't seem to shake as much.
Old Jun 3, 2004 | 08:44 PM
guysohigh's Avatar
SimStones
Originally Posted by Fosgate Fan
600 dollars?! damn!
What is a broadway mirror???
Old Jun 3, 2004 | 09:19 PM
Originally Posted by guysohigh
What is a broadway mirrir???
It's basically a clip-on mirror that give you a wider rear view.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33699
vingodine
45
May 21, 2016 12:46 PM
Bluenissan
Sep 20, 2015 08:54 PM
flu2000
Sep 8, 2015 02:23 PM
Maxilano
Aug 31, 2015 07:33 PM
wpr
Aug 5, 2015 03:28 AM
