Driver's Side Windows - AUTO UP Not working correctly. It goes up and comes down 3in
I have a 2000 Maxima with a small problem. I was wondering if anyone else had this problem.
When I hit the auto up on my power window on the driver's side...it goes up to the top and comes down 3 inches! I can manually roll it up. The dealership told me I probably need a new regulator! I DONT BELIEVE THEM!!!
Anyone have this happen to them?????
ANY HELP WOULD BE GREAT! CAN I FIX IT ON MY OWN????
the same thing sort of happens to me...but mine only goes up a few inches then goes back down to where it started. ive resorted to just holding the button to bring it all the way up. id be curious to know if anyone has any insight
and on the topic of windows...why does it seem like my window motors are really weak and arent getting enough power?
I had this problem on my front passenger side window. I brought it in the first time and they adjusted something in the door. That fixed it for about a day then I brought it back and they replaced a part that guides the window in the track or something to that effect. They had told me that if it came back they would have to replace the window motor but it has been fine for almost a year now. I also had a problem with my driver side window that was making a grinding sound and thety ended up replacing the window motor.
I have the same problem with my passenger side window. When I took it in, the dealership saw my aftermarket LCD and stereo and told me my electrical system was messed up and then tried to charge me $2600. I got outta there and never went back. Moral of the story: be careful if you have aftermarket stuff, yes, even a stereo.
The window motor senses resistance. Just like garage door openers do, when it is going up on auto and something gets stuck in the path (like your fingers) it will go back down a few inches to protect against injury.
Clean the tracts on either side of the window. I've also heard of people here and the dealer using silicone spray in the track and moldings to help fix this problem. Also sometimes it may need to relearn the stop point for the window, you can do this by helping the window up after you hit the auto button.
It doesn't happen all the time which makes it even stranger.
It Worked Danl!!! Maxima Genius!
He was right....
FOR ALL WHO FIND THIS THREAD HERE'S THE DIRECTIONS:
1.) Remove 3 screws
- Remove grey button under mirror. Remove Screw.
- Remove casing behind dor handing (becareful). Remove screw.
- In handle in door remove black button. Remove Screw. Remove tray.
2.) Take a wide tool and start at the hinge and pop off door panel. Every 4-5 inches there's a pop-off. Go the whole way to the latch. About 6-7 pop-offs.
3.) Lift up on the panel....any presto.
4.) Remove plastic layer to the left of the speaker (dont worry about the glue) it resticks.
5.) Look for a rubber button outlined in red. (about 3-4 inches left of the speaker).
6.) Roll the window the whole way up (dont use auto-up feature).
7.) Press and hold button.
8.) Roll the window down. (dont use autodown feature).
9.) When the window is down let go of the button.
10.) Roll the window up manually and down manually (no auto feature).
11.) NOW ROLL-UP USING AUTO FEATURE AND PRESTO FIXED!!!!
GIVE IT UP TO DANL!!!!
1.) Remove 3 screws
shaunkey1
Aug 18, 2015 10:09 PM
erniel
Aug 8, 2015 09:32 AM
