HOw to drain upper radiator hose?
Old Mar 26, 2001 | 07:06 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I'm gonna finish up the engine dress-up tommorow and I wanna do the radiator upper rdiator hose, but how do I drain the fluid currently inside it? and once its drained, do I have to add more fluid? thanks
Old Mar 26, 2001 | 07:43 PM
94SUPERMAX's Avatar
First go under the car and open the rad plug that's in the right bottom corner of the rad. Once you drained some fluid from the rad you can undo the end that is attatched to the rad and lift up the hose once you get it of the tip, then get a container and tilt the hose so that it all flows into the container, after that you can remove the other end. When you put the hose back on you need to fill the rad to the top then start the car and let the coolant circulate for about 30 seconds so it get's sucked into the engine, then go and top the rad off and put some coolant in the reservoir.
Old Mar 26, 2001 | 07:49 PM
primeevil711's Avatar
you definetely need to add more fluid after you replace it cuz if you have air bubbles in your coolant system the air pressure can blow any of the hoses out. if I were you I would just do a flush and refill on the radiator and put all new fluid in there.
Old Mar 26, 2001 | 09:05 PM
DA-MAX's Avatar
Okay, thanks guys, heres a recap-->
lets make sure I got this.....
after radiator is completely drained and eveything is put back together, how much coolant goes back in the radiator and how much in the resevoir? just one "bottle" will be enough to top it off? thanks for the help guys
Old Mar 26, 2001 | 09:31 PM
94SUPERMAX's Avatar
Re: Okay, thanks guys, heres a recap-->
No prob.
As to how much to put in I don't know for sure keep toping it up till it's nice and full and fill the reservoir half way, so I was told.
After you run the car for for a while and then check the level and fill the rad to the top.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
JonBlz
Oct 5, 2015 06:02 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
