HELP my car is running like crap.
I removed the TB/IM restrictor on Friday and everything seemed fine until Saturday on the way home from a friends house. When I first start the car it will barely idle even shutting off once. If I ease in to it everything is fine until you reach 4500 rmps then it will immediatly cut back to 3000 and if I floor it the rpms will jump up to around 4200 and hover there but the car barely accelerates.
My car is a 2k auto with 70k miles.
Originally Posted by black2kse
Make sure the hose that connects your air filter to the MAF is secure. Also check the hose that connects MAF to the throttle body. You may want to disconnect you bettery for a few hours as well. Good luck.
The tranny slipping shouldn't cause the car to shut off.
Shane
hmm i was planning on doing this, this weekend but this is giving me second thoughts....you should ask ICE and the others that started the thread on the TB/IM restrictor thread since they know more about it...good luck though
The strange thing about this it that it seems to be getting better on its own. Now I can give it a little more throttle before the bog begins and the RPMS will go to 5000 instead of 4500 before it goes back down.
Removing the restrictor may have created a condition where the ECU needs to be reset -- try leaving the battery disconnected for awhile, as has been suggested, and see if that doesn't clear the problem up. If not, check out your MAF.
Originally Posted by msdins
I left the battery off for about 12 hours and it didnt clear up the prob.. What is the normal (if there is a normal) amount of time to leave it disconnected?
if it aint' broke.................
I had the Solenoids and the TCM replaced but I still get that horrible hesistation it's gotta be the MAF here's a useful thread about cleaning the MAF
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
