Y-pipe Nightmare!!!!!!!!! Help!!
Old May 25, 2004 | 11:36 AM
Seximus Maximus's Avatar
I put a new y-pipe in the other day. But while tightening the last of the front three nuts the bolt broke off!!!! So am i screwed and have to buy a new header for the front or what? Those bolts are part of them.... right? All molded into one piece? So ya anyway im rollin with 2 bolts holding the front only..... i dont hear any leaks but im sure during heavy driving it prob does. please any suggestions! im prob screwed arent i..........
Old May 25, 2004 | 11:51 AM
THT's Avatar
THT
Throbbing member
Is there even a nub sticking out or is snapped off completely? I don't think the bolts are a part of the header because I have the bolts that screw into the header and Y-pipe sitting in front of me. I was going to replace the ones that came with the car but didn't bother as they were in decent condition. Anyway, if there is a piece sticking out, try to remove it with a pair of pliers.
~THT
Old May 25, 2004 | 11:53 AM
azmaxipad's Avatar
or if you can see if you can look through the engine bay to the top of the header and that would help you to see if the bolts are a peice of the header. If there is a nub try hitting it with a hammer to brake it loose it could be there is a ton of build up on the other side
Old May 25, 2004 | 12:14 PM
ill try that. or ill take it to a mechanic buddy and have him work his magic....i hope.. damn things are a pain in the **** because of the rust factor associated with exhaust pieces.... can we say "Cement"! Im not Mr. mechanic by any means, im just very mechanically inclined so small projects like this are easy for me. if im wrong about any of the things i posts by all means feel free to correct me or suggest fix's I luv the max community u guys rok!
P.S. Using P.B. Blaster on the nuts before taking them off is the ONLY way to go, that sht works great!
Old May 25, 2004 | 12:17 PM
azmaxipad's Avatar
my y pipe is all rusted too so I already started spraying it with P.B. blaster for when I do put my new y pipe on
Old May 25, 2004 | 07:33 PM
oTranscendental's Avatar
they are not part of the header, the are double sided studs, you will have to get new ones if the snap, and look out if they snap inside the block.
You will have to drill them out. Had it done on my 3rd gen. What a bich.
Old May 25, 2004 | 07:58 PM
Taken2DaMax's Avatar
True the only way to get off the orginial y-pipe is to use Pb blaster. I did it to my car and go it off easily.
Old May 25, 2004 | 10:47 PM
snapped flush with the surface. so i guess ill take it to a mechanic and get it taken out.. think the bolt costs like 10 frickin bucks too >.<
Quickywd01
Sep 21, 2016 09:36 PM
wingnut2006
Sep 19, 2015 06:13 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
