Manifold Stud Woes
Manifold Stud Woes
okay so Im pretty sure i have a cracked manifold which i am going to replace but I look under and see a hole where there should be a screw to secure the manifold so i know I have the studs to replace which i want to do it all.
I read some threds abotu this but some issues im having i still need answers.
are the studs dealer only products? Also Does anyone knwo where ot get a new manifold for under $189. Also could someone lead me in the directions beside the dealer or the cheapest dealer for these studs.
thank you all for your time
now i have to find the write up on how to get to it all the thred i looked at helpped but didnt tell me where to remove what.
http://forums.maxima.org/showthread.php?t=277441
i have a similar problem, one of the studs sheered of the exhaust manifold where it connects to the head, i'd like to fix it, but i want to know if its worth it because i'd like to sell the car soon anyway, anyone know how much this would run me?
I just bought a full set of studs, washers, and nuts from Courtesy Nissan. Cost me about $100 for enough to do both sides (12 of each). As I was choking on the price, I also thought about whether or not I could get these at a hardware store or something, but as I thought about the amount of work ahead of me, I decided that it wasn't something I wanted to do twice. So, that and about $20-$30 worth of gaskets will get you the parts. Unless you need a new manifold. I lucked out and found a new rear one on ebay for $50. Normally they sell for about $150 there. As for the front one, I went ahead and bought a used one on ebay for about $10, just in case I need it. I'm figuring on about 3 days do do the work based on what I have read from other guys who have done it. Knowing me, tho, if I think it will take 3 days, it'll take 5...
Here's some links that could help ya...
(1) A how to on stud replacement
http://www.4dsc.com/articles/drivetr...ld_studs.shtml
(2) What I replaced mine with
http://forums.maxima.org/showthread.php?t=284277
(3) ARP
http://www.arp-bolts.com/media/pdf_files/SC_54-58.pdf
(4) More info on stud replacement
http://forums.maxima.org/showthread.php?t=285587
(5) More info on stud replacement
http://forums.maxima.org/showthread.php?t=312331
(3) ARP
Good luck w/the project
