ECU screw missing on 99 maxima ???
There's a sticker over it which you have to break to get to the screw. Could this be your problem? http://vbxmaxima.8m.com/ecu.html, the third pic down shows the sticker already broken.
Originally Posted by cheenzine
Is this possible, I followed the steps provided by this website to diagnose a check engine light. But it looks like there is no Screw to turn inside the ecu.
I had the same problem at first then I asked in forum.
That's the screw. Just be very careful when using it to not round up the head.
Originally Posted by catalinoiu
There is no big flat screw like seen in the forum instructions. It is only a small, and very fragile plastic POT accesible with a small philips screwdriver. The label may say "Idle adjuster..." or something like this.
That's the screw. Just be very careful when using it to not round up the head.Thanks i will check it out, you are right i was looking for a big flathead once the sticker was broken . . . its hard to see in there anyways.
Finkle
Sep 27, 2015 09:53 PM
Superbform
Aug 11, 2015 08:10 PM
kirkhilles
Aug 8, 2015 10:53 AM
