Which fuse is blown? I do nto have the little plastic thing.
I lost the plastic cover to my fuse box, and i think one of my fuses went out. my clock and my homlink is not working right now. i installed a remote wire and while in the process i heard a fuse blow. whcih fuse is it, and where is it located?
give row and number down!
It's probably the one all the way to the right at the very top. It's sort of separated from the others, if your CD player still works this might not be the one though. Just go over every fuse and see. The time it took you to make the thread and wait for replies, ypu could've alreeady found it. To answer your SIG question, they put the wienie on a stick and dip it in a big pot filled with the corny exterior.
get a voltmeter or logic probe, then probe each fuse. the fuses should show 12 volts on each "prong". if a fuse is 12v on one side and ground on the other, it's blown. or you could just visually inspect the top of the fuses and see which one is blown.
bigfrank
Oct 1, 2015 12:51 PM
