where can I find coil packs for cheap????
Old Jun 8, 2004 | 05:35 AM
maximalnemisis's Avatar
hello orgers I would like too know where I can find coil packs for cheap I went too auto zone and had trhem check for ghost codes (my cel wasnt on) and they told me I have 2 codes k.s. code and misfire on cyl.#5 so I know that the car has been sluggish lately and especially under load or going up hills and in low rpm you can feel it start too slightly missfire so I know from everything I've been reading on the org.lately thats most likely the prob any help would be appreciated... also should I consider coil packs from a junk yard if they look good? also will any year i.e 95,96,97 interchange with me? I'm a 98 thanks
Old Jun 8, 2004 | 05:58 AM
MrEous's Avatar
^ Jeff™
sx7r is selling his used coil packs...
http://forums.maxima.org/showthread.php?t=316068
$50/coil + shipping...obo
Old Jun 8, 2004 | 08:41 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
jerryromenissan.com us promo code "maxima" to get 12% off it comes to about 55-60 dollars. each. if you need some injectors, most likely if your coil isnt to blame, i can sell you some used injectors for pretty cheap.
Old Jun 8, 2004 | 12:25 PM
Brudaddy's Avatar
Those words "cheap" and "coil packs" don't really go together.
Both of the suggestions are about as good as you are probably going to get.
Make sure you don't get the Hanshin ones, as they are the bad brand that are in there.
Get the Mitsubishi brand, and you should be set.
I would just replace them one at a time and start with #1, then #3, and then #5. No need to replace them all if they all don't need it. That will run you over $300.
Old Jun 8, 2004 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
Hanshins have lasted me over 220k miles
Old Jun 11, 2004 | 07:06 PM
PharoNDmist's Avatar
Damn!! Thats the same exact problem I have with k.s. and the misfire in cylinder #5. I'm burning a load of gas with these problems
Old Jun 13, 2004 | 08:13 AM
tweeter007's Avatar
Napaonline has them for $68-72 brand new.
adamgalazka
Sep 8, 2015 01:27 PM
crazyespn
Sep 3, 2015 01:30 PM
