Stalling... akward acceleration
Okay, I have a 1990 Maxima SE. In the last week, I have been having some problems with acceleration, stuttering like. And in the last couple days, it has had a "jittery" idle and stalled on occasion at stoplights. (which is a hassle, because the car is an automatic) I thought it was the Oxygen sensor, but then I started to question my diagnosis because I don't remember the O2 sensor effecting the idle before I replaced it on my 300zx.
Any help is appriciated... thanks!
Well, if it means anything, I filled it up with Premium when I went out just now and it seems to run a lot better. I'm sure this is only a temporary solution so I would like to know what I can do to fix my Max.
It could be a bad fuel injector or two, spark plug wires, cap and rotor, or a few other things. If it starts idling "jittery" you can leave the car running and unplug the spark plug wires one at a time to try to narrow the problem down to one or two cylinders. If you pull the wire and there is a difference, the cylinder is okay, if it makes no difference, it is a dead cylinder and that could mean a bad fuel injector or plug wire. Just don't get zapped when doing this.
Hmm I'd say it does it more after it has been running a bit. I can't believe how horrible the car is, I inherited it from my mom as a mode of transportation until I get another job, and it just seems like in the last 6 months the car has gone downhill. All starting with a small fenderbender/hit and run. Never caught the guy, either.
Sorry about the color thing, I don't browse the boards that often. I'll change it soon.
Hope this helps!
as quoted by Identifix:
Fast Fixes: Misfires, Bucks Or Jerks Under Load
Likely Causes
Spark Plugs -
Worn, faulty, fouled or incorrect spark plugs can cause the engine to misfire, buck or jerk under load.
Spark Plug Wires -
Leaking or high resistance spark plug wires can cause the engine to misfire, buck or jerk under load.
Distributor Cap and Rotor -
Weak or erratic spark output from a faulty distributor cap and rotor can cause the engine to misfire, buck or jerk under load.
Ignition Coil -
Weak or erratic spark output from a faulty ignition coil can cause the engine to misfire, buck or jerk under load.
Overlooked Causes
Intake Air Boot -
A cracked, torn or split intake air boot between the mass air flow (MAF) sensor and the throttle chamber or loose clamps for the intake air boot can cause the engine to misfire, buck or jerk under load.
Throttle Position Sensor (TPS) -
Erratic signals from a defective TPS can cause the engine to misfire, buck or jerk under load.
Copyright ©2004 Automotive Information Systems, Inc.
Likely Causes
Spark Plugs -
Spark Plug Wires -
Ignition Coil -
Overlooked Causes
Intake Air Boot -
CHANGE YOUR O2!!!!
if it's better when it's cold i can almost bet it's O2.
When the car is cold (ie not up to operating temp) the computer is in open loop mode, and will dump a predefined amount of fuel into the motor (ie your o2 sensor has no effect) if it runs like crap cold, its not a sensor its a mechanical problem (ie leak somewhere or plugs). If its fine until its warmed up your o2 sensor is a likely problem.
Need help
23
Oct 2, 2015 08:56 AM
