anyone actuallu know
Old Jun 17, 2004 | 05:30 AM
88MaximaSE's Avatar
just wondering if anyone here knows anything about the air conditioning system in the maxima. mine stopped working. i just charged the coolant and checked fuses and relays. rpms do jump when i hit the AC bottom. I bought a 98 compressor but i'm not sure if it will fit in my 95 max or if that is even the problem. anyway, only repsond if u know wut ur talking about. thx i'm trying to pin point the cause of the problem
Old Jun 17, 2004 | 03:44 PM
macallik's Avatar
did you check the fuses?
Old Jun 17, 2004 | 04:46 PM
95bkackmax18s's Avatar
do you know how to check if the compressor is working?the way i did was as your lookin at your engine, to the top left there is a 'plug in' ( follow your ac line to make sure).. but its at the top, top left. pull the plug out, the part you pull out has two little holes- thats cause it "plugs into", just take a wire and put each end in each little hole and if you hear your rpms idle, your compressor is good. i just did this a few days ago and its very easy and it wont hurt your car, so....
Old Jun 17, 2004 | 07:35 PM
Nismo's Avatar
maybe its not full of refrigerant and even when you did add some, its probably still not enough
Old Jun 18, 2004 | 06:46 PM
88MaximaSE's Avatar
Ac Sux
i'm not sure what you mean? take the wire plug out and short it. can u be more clear please. anyone else have any knowledge.
SurraTT
Jul 9, 2005 11:50 AM
