LED Window Switches & more LED lighting
Check out these pics of my LED-ed interior...I hope to add some more LED lighting when I get some time...maybe even "LED"the side markers once I figure out how to. Let me know what you think
http://www.cardomain.com/memberpage/631349..SCROLL DOWN on the page
Thanks to
http://www.alexhsu.com/maxima/ledinstall/
redmax99sel
for all the help
Thanks to
redmax99sel
for all the help
Originally Posted by Pri63
Check out these pics of my LED-ed interior...I hope to add some more LED lighting when I get some time...maybe even "LED"the side markers once I figure out how to. Let me know what you thinks
Thanks to
redmax99sel
for all the help
Thanks to
redmax99sel
for all the help
That's what I did.
Originally Posted by GaMax97GLE
Looks good. For the LED side markers...get some 194 LED bulbs from here: http://autolumination.com/194.htm
That's what I did.
That's what I did.
Originally Posted by sheidt
GaMax - I haven't taken off the side markers, so this may be a silly question, but, do those 194 bulbs that you referenced just fit into the slots that the existing OEM side marker bulbs were in, or do those LED bulbs need a different "housing" to plug into? Again, sorry if this is an obvious question, but I figured you could easily tell me, since you have obviously done this mod.
They should slide right in.
The LEDS are clear. They come with a colored base though. I would get the ones that have 6 LEDs in the bulb. I got the single bulb ones and they are alright, but it would be better if they were brighter. You can see the colored bases a little, but you will notice on autoilluminations site you can also buy white bases to replace the colored ones if it bugs you too bad. Honestly its hard to see them through the clear corners though.
I was wondering if there was a special paint I could spray the clear sides with that came close to matching my titanium paint that was still translucent to let light through from the bulbs and still at least partially reflective. Just thinking about how that would look with a matching color, although I think the clear would probably look better.
I'll bet the bright-white matches up real nice with your glacier white color exterior.
-J
On the link to the "how-to", there aren't instructions on the passenger or rear window switches.... in fact, it almost discourages you from attempting. Can you give any insight into the tricks do doing it correctly?
Thanks -
Brian
Thanks -
Brian
Thanks -
Brian
Thanks -
Brian
Thanks to
redmax99sel
for all the help
Thanks to
redmax99sel
for all the help
Looks good man!
Glad my advice helped out!
By the way, i am redmax99sel from instant messenger... but when having owned 5 maxima's, it is tough changing you screen name everytime... lol.
-Chris
By the way, i am redmax99sel from instant messenger... but when having owned 5 maxima's, it is tough changing you screen name everytime... lol. -Chris
Thanks to
redmax99sel
for all the help
Thanks to
redmax99sel
for all the help
Originally Posted by 2k3TitaniumSe
Looks great mang. What size LED was used it the key ring?
If you're going to do the key ring, you'll have to use a resistor, you can pick them up from radioshack color code is Orange, orange, brown, gold. Let me know if you need any help...
I'm also going to try and post some how-tos on the passenger switches.
Originally Posted by MIXXMAX
Looks good! I did the same, but went a little further and added some blue LED's elsewhere, also....like the guage cluster and under the A/C unit.
I used 3mm Blue 6000mcd LED bought off of ebay for 2.50+S&H for 20 of these bulbs. The seller was mckenkenken. I'll let you know these bulbs are bright, when my security light blink it lights up the car.
Originally Posted by maseo77
PLEASE tell me how u did that, my factory lights under my ac unit dont even come on anymore and i dont know how to change them.
Originally Posted by thomasd cook
Check out my homepage. I've got a write-up on all the doors and I was the first one to do the illumination light under the AC controls.
where is your homepage? i want to do all doors with white LEDs, cant seem to find a good write up for it thanks!
vingodine
45
May 21, 2016 12:46 PM
kjm900r
Aug 5, 2015 07:14 AM
