How do u properly take off S/C to replace camshaft position sensor?
Old Jul 3, 2004 | 10:41 PM
meccanoble's Avatar
Sports Button FTW
friggin sucks i got a bad sensor. My car just cuts off out of nowhere and if u try to start it, it acts as if it has no gas. It just keeps turning over but wont finish the start. I got the 01 01 code and i guess i just have to replace it but the S/C bracket seems to be in the way and i know there is more to just removing the bracket. Belt, pulley, gotta be so much more stuff. I have a V2, can someone tell me what needs to be removed so i can get to this sensor?
Tools needed, things to watchout for, etc. I'm a noob, i need this to be thoroughly explained to me. thanks.
Old Jul 5, 2004 | 07:41 AM
BlackCat's Avatar
RIP '98 Maxima SE
I posted a brief guide in another thread on how to take off the SC:
http://forums.maxima.org/showthread.php?t=316611
Old Jul 5, 2004 | 01:54 PM
meccanoble's Avatar
Sports Button FTW
you have a PM, i need your help
Old Jul 5, 2004 | 02:06 PM
BlackCat's Avatar
RIP '98 Maxima SE
I PM'ed you back. Don't forget that everyone else who as a blower can help you here!
Old Jul 6, 2004 | 06:59 AM
Chunger's Avatar
My other car is a Hybrid
You don't have to take off the S/C to remove the bolt retaining the CPS bracket (V2) for the sensor, right?
Sometimes if you don't push the CPS harness back in COMPLETELY it will not start too.
Old Jul 6, 2004 | 07:32 AM
maximase86's Avatar
I love lamp.
IIRC, it's still a PITA to get to CPS with the bracket on. Removing the S/C isn't that hard...just takes a couple of times before you get really fast at doing it. All you need to do is:
1. Remove charge piping
2. Loosen idler pulley
3. Undo the S/C belt from crank pulley
4. Loosen the clamp for the oil drain line
5. Depending if you want to remove the S/C completely, or move it to the side, remove oil feed line
6. Undo all the bolts for the S/C bracket (also keep in mind, there is an altenator mount bolt that goes through the bracket, be sure you do not completely remove this....just back it out enough to clear the S/C bracket...it's a PITA to put back in).
7. Remove S/C or move it out of the way to do work on your CPS.
8. Installation is reverse.
My suggestion since you have everything out, if your belt is looking worned, I'd replace it while you have the S/C out, or moved to the side. Either way, the more you remove and install the S/C, the quicker you can do it. iansw and I have it down to like a 30-45 minutes now.
Old Jul 6, 2004 | 12:11 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yeah, i have it down to that too.
mecca--did the mechanic snip a wire or something on the install?
Old Jul 6, 2004 | 01:40 PM
maximase86's Avatar
I love lamp.
It seems to me the the CPS is in a really bad spot that the harness seems to either rub up against something, or some how can get stuck in the way that it could ground out. I notice this problem when we reinstalled iansw S/C back in January. I wonder if there is something we can do to protect the sensor and harness??
S
Old Jul 7, 2004 | 06:51 AM
JAY25's Avatar
Run that wire over the bracket not under the bracket. If you dont, you may get stuck in the middle of no where like I did. That was a $500 bill for me.
Old Jul 7, 2004 | 08:02 AM
Chunger's Avatar
Yep... Just looked at mine... it's tight but if you ran your wiring over the bracket, you can take it off without removing the SC bracket...
Old Jul 8, 2004 | 05:32 AM
meccanoble's Avatar
Sports Button FTW
my wire is ran over. I put a ratchet on the bolt and as i proceeded to twist, the engine mount was in my way and didnt give me enough room to to loosen bolt..at all. sucks, so close.
Old Jul 8, 2004 | 07:47 AM
Chunger's Avatar
I had to use a small open ended wrench... it is very tight though... but it may be "easier" to remove the SC if you can't.
Old Jul 8, 2004 | 12:58 PM
JAY25's Avatar
go to NAPA and go buy one gear wrench the type that twists at the handle so when you start turning you can turn the wrench away from the mount and turn it loose.
buy one number ten. I have a full set of these and two full sets of the regular gear wrenches. These come in very handy, especially if you have that SCer
Old Jul 8, 2004 | 01:14 PM
BlackCat's Avatar
RIP '98 Maxima SE
Hey Jay! Thanks for the lead!
Old Jul 8, 2004 | 02:21 PM
JAY25's Avatar
thanks! These wrenches rock you guys have no ideal how much gear I got when my brother was working at NAPA I got close to a grand in just tools.
Old Jul 9, 2004 | 07:07 AM
BlackCat's Avatar
RIP '98 Maxima SE
I forgot what tool you use for bolt #14. I'm looking for a better one than my ghetto allen key duct-taped to a Craftsman screwdriver!
Old Jul 9, 2004 | 07:11 AM
JAY25's Avatar
this is my combo:
http://maxima.cardomain.com/memberpage/259227/4
scroll down youll see it. Its a craftsman wrench
Old Jul 9, 2004 | 07:18 AM
BlackCat's Avatar
RIP '98 Maxima SE
this is my combo:
Oh yeah! I remember it now! I've looked at all of the Craftsman tools at my local Sears store but I could never find it! Is there a part number for it?
Old Jul 9, 2004 | 10:42 AM
JAY25's Avatar
Craftsman 1/4 x 5/16 in. Wrench, Offset Ratchet Box End
Ratcheting box end wrench. Offset-style standard 1/4 x 5/16 in.. 12 pt. openings. 4-1/4 in. long. Features thumb-operated reversing levers. Exceeds Fed. Spec. GGG-W-001405 for torque capacity.
Sears item #00943361000
Mfr. model #43361
Old Jul 9, 2004 | 11:02 AM
BlackCat's Avatar
RIP '98 Maxima SE
Thanks! that is awesome!
AnsonJ
Jun 2, 2017 01:35 PM
Rage Maximus
Sep 3, 2015 12:26 PM
maxinout93
Aug 20, 2015 02:17 AM
wingnut2006
Aug 15, 2015 04:16 PM
BobMax
Aug 15, 2015 12:35 PM
