B&M STS Installation / Changing Brakes
#1: Does the B&M STS come with good installation instructions, and does it require removing the catalytic converter and some work underneath the car; or can it be done solely from the inside?
#2: What would you rate the difficulty of changing the brakes on our maxes? I mean... It's just removing the tire, the caliper, cleaning all the components correctly, resetting the piston and putting it all back together right?
I dont know anything about the shifter... I have an auto... however the brakes are too easy... I mean really really easy. Take the tire off... the caliper floats on the rotor so all you have to do is take out the 2 bolts on the calipers... or if your lazy like me, you can take out the bottom one and loosen the top one and swing it around... get a C clamp to push the piston back in and put in the pads.. its that easy.
Originally Posted by Big D
The shifter is pretty easy. Having a buddy to help you is even better. Instructions are probably in the HOW TOs.
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
