Timing Belt life (years/miles)???
I just bought a 93 GXE with 17,000 original miles. I was talking to one of my buddies here recently and he said the timing belt on his 91 300ZX lasts 5 years or ???? miles. He advised me to get my timing belt changed. I've always heard change the belts around 60,000 mile intervals, but I've never heard 5 years. I'd hate to have to pay to get it changed with such low miles, but I don't want it to break either. Have any of you had experience with this, or have any knowledge you want to share? Thanks in advance.
Life of timing belts
Corrct me if I'm wrong, but stock from the factory (original belt) life is 60,000 miles. Replacements last 100,000 miles. I am not sure about actual years, I don't know if they wear out with time, but...
you can't be too safe with timing belts! When in question, get it done.
BTW...that sounds like crazy talk, only 17,000 miles original. Are you sure it's not on a rebuilt engine? That car's not even broke in yet. What did you have to pay?
Re: Life of timing belts
P.S. My roomate has a 91 GXE and he's got 181,000 trouble-free miles on his......still runs like a dream (no smoke, no problems)! That was another influencing factor that made me get this car.
Yeah, i've heard 60,000 also, but nothing about years??? Anyone else heard any different. Help me out here guys. Thanks!
my dad has a 97 galant ,bought it new ,he works in the city so he takes his old lexus .the galant only has 23000 miles . it sits in the garage a lot and when i drive it sometimes its sluggish..so i advise you to take that car and give it some good highway miles
Should I get the timing belt replaced at 17,000?
Originally posted by Canuck
60000 miles on replacements as well. If there is fluid on it you should replace it just in case. No need to kill the car over a bad belt.
My manual say 60,000 miles and doesn't spec. the age. Rubber tends to crack with age, heat and oxygen exposure. I had my changed last year with 60,000 miles. The all the belts looked brand new. If it were my car, I would likely change them all or have the belts inspected, but my mech. always says the parts on my car look good unless they broke. As for new belts lasting 90,000 that's only on the ones with a special groved wheel and belt. I think they came out only on or after late 93 version. Call the dealer with the Maxima's SS to find out if it has the new design and can take the new longer life belts (my 93 counldn't). $9500 is a great deal.
Rubber can and will crack with age. I do know that on the NSX that Acura states 5 years or 60k miles so I believe there is something to replacing it. That being said, I doubt you will have issues with it, however it would be very good insurance to go ahead and replace it anyway. Basically if you do it yourself it shouldn't cost much and honestly it's not very hard to do. Also you could get away with just replacing the belt which even if you go OEM is only about $40 - $50. The total cost if you are looking to do it yourself would be probably only be ~$60.
Good luck,
Good luck,
Like Brian stated, change the belt!
Rubber deteriorates and breaks down with age -> 5-6 years or 60,000 miles. Why risk the engine?
FYI, the t-belt on my Max was changed over 2 years ago. The POS snapped, bending 18 valves
It CAN and WILL happen at any time or age, it just sucks mine went after 2 years (only ~ 14,000 miles).
I have an 89 w/208,000 miles. I changed my first one at 107,000. My experience is the fan belts and the timing belt age alike. I would check the fan belts for cracks and looseness. If the fan belts don't look good then change the timing belt too.
At some point, they switched over to a chain and I wish I could remember how to look that up.
Good luck,
Tom
Good luck,
Tom
Maxine has 91,000 on her and I am already planning to change the belt. Like they said, rubber tends to deteriorate with age and you really don't want to take a chance with messing up your motor. I'd rather pay the $900 now than $2700+ later.
Belt life
Ok here is the specs Prior to 1994 the timing belts
have service of 5 years 60,000mi replacements have the
same interval ( 1989-1994 max T-Belt NISSAN part#
13028-85E86) after 1994 timing belt have a life span
of 100,000mi ( they have larger cogs on the belt
NISSAN part# 13028-0B785)
Let's go buy new Maximas for $9500.
What do you think, would you have gone for it too?
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
Apr 8, 2018 09:23 AM
Ray229Harris
Sep 16, 2015 08:16 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
